Pro Tools doesn't see 003
I unplugged my computer from my 003, moved everything 3 feet, pluged it back in, and now my computer doesn't see my 003. The 003 says 003 Offline. Plus when I boot up protools it says Your I/O setup has changed since the last time this session was saved.. Check the I/O Setups window to see what's changed.
I tried using a different firewire cable. Tried plugging the firewire cables into different inputs. Now what!?!?! |
Re: Pro Tools doesn't see 003
Change buffer size to 1024 and try again.
MacPro 2.66GHz 8Gb RAM Mac OS X 10.7.5, Pro Tools 10.3.3, DIGI 003 Factory, LogicPro 9.1.8, Tascam FW-1884, Adam A7, Roland TD-20, Yamaha SY-99, Audiotechnica ATH-M50. |
nope, that don't work
Everything was working 100%. Nothing got dropped. I moved my room around now it doesn't work. The 003 seems fine when I turn it on. Pro Tools is working fine. But the 2 don't connect.
Was the Computer and or the 003 power on while you disconnected it, because if it was then you probably fried your firewire
You can chack that by going to System Profiler and see what's listed under FireWire. You can also try fire up 003 before starting the computer.
Yes the 003 is listed under the FireWire area of the System Profiler.
Also I have tried rebooting my computer a number of times and re-starting the 003 before starting the computer. |
Trashing preferences?
Oh my goodness, that worked. Thank you guys very very mucho!!!
Glad that helped! :)
