Old 02-06-2022, 07:04 AM
Fritz Fritz is offline
Default Re: saving error message
I did make a copy on the int of my Mini. That works.
I will try to copy back to the LAN'd drive.
Just weird that I can't open any session from externals without copying to int.
In theory, if there was a flag on a file allocation table, I assume that would be a hidden file and/or folder on the boot drive, not the external?
Or would there be on both drives?
"Do not fear mistakes. There are none."
Miles Davis
Old 02-06-2022, 07:31 AM
looked for hidden files and/or folders on both the boot and the external.
nothing that stands out.
Miles Davis
Old 02-06-2022, 08:57 AM
I haven't worked with network OS technology for two decades so my knowledge is out of date. It used to be that the file allocation table (or equivalent) was kept on the same partition as the files (not necessarily the boot drive). Another thing you might want to look as is if the LAN drive is partitioned/formatted with a compatible format type (some formats are APFS, Mac OS Extended (Journaled), exFAT, Fat32, NTFS, etc). Protools specifies which ones are recommended, but I don't have that in front of me at the moment.
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 02-06-2022, 10:33 AM
haven't been able to find a partition compatibility map, but the files have been working. So I think PT didn't like whatever unexpected quit or close happened and is now being miss bossy pants.
Miles Davis
Old 02-06-2022, 11:08 AM
bradch00 bradch00 is offline
Apparently there’s a temp file written for this;
Check out the section; Prevents Others From Overwriting Session
https://avid.secure.force.com/pkb/ar...-Release-Notes
Pro Tools, Studio One Pro
2022 Mac Studio M1 Max 64GB-1TB NVME
OWC Thunderbay Mini (4TB SSD)
OWC Express 4M2 (4 X 2TB)
Interface: Presonus Quantum
Presonus Faderport & Faderport 8
Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128
BM5A, KRK VXT4, Equator D5
2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig)
Old 02-06-2022, 11:16 AM
looked for it. but alas ....
Miles Davis
Old 02-06-2022, 01:37 PM
Do you have Preferences > Collaboration > Prevent Others From Overwriting Session
Selected? (Turned on)
If yes... what happens when you turn it off?
Old 02-06-2022, 01:39 PM
that pref is and has been off.
Miles Davis
Old 02-06-2022, 01:56 PM
Sorry that's all I have....
Old 02-06-2022, 01:59 PM
ok. it's an odd one.
I may end up uninstall/re-install.
Miles Davis
Error When saving:Could not save because I/O error (5) amonk91 Pro Tools 12 1 05-07-2015 12:33 PM
Pro Tools 11 activation error-licensing service not running error message Seismic Sound Windows 5 03-23-2015 05:35 AM
Saving error message P Mackey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-18-2007 12:28 AM
wierd error message stops me saving etc. gfunk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-11-2007 12:15 PM
Error Message appears when saving a new session Anduril 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-14-2005 03:50 PM
