compression setting causing a -10db loss
My compressor setting mysteriously changed. I spilt coffee on my desk, but I opened my dbx266 and nothing got in.
Anyway, when I cleaned up and put everything back together, the compressor seems to be kicking in a lot fast and harder. My audio going in has dropped about 10db in Pro Tools 11. I am a voice actor and know nothing about pre sound. I had an engineer set up my studio. I have to get another engineer back in, or maybe you guys can suggest something. I know this is the compressor because when I am in my audio booth I can hear the highs through the headphones. After my first syllable I lose those highs and I think I am looking gain. My setting are the same, because I marked them in case they were bumped. That is why I can’t figure out what changed. Last week my audio was good and strong….up to and around 6db coming in and now I am loosing 10db. I have a TLM104 going into a presonus blue tube amp. Then it goes into the dbx266 Threshhold at -18 to 20 Ratio is just past the halfway mark of 2:1 and 4:1 Attach is almost on Fast Release is almost ¾ of the way over toward slow And Output Gain is about -3db I have played around and can’t get anything to change. I am using an mbox 2 and I have played with the gain on my mbox and presonus and still have the same problem. This is a bit of an issue, because I am trying to record an audio book, and the compressor is allowing some strong attacks, and keeps everything else around -10db. I want to gain back that -10db. It also makes the audio sound less “crisp” and I have to add some eq on the high end. One thought, should I move everything over to the other channel on the compressor and see if I have a bad channel. The dbx will be a year old in Jan 2014. Thanks. |
Re: compression setting causing a -10db loss
You connected the output's to
The wrong connector? Maybe
I will check, but I should have mic to preamp, to compressor to mbox.
Have you accidently set the "Pad" on the Mic to -10 dB or possiibly some other gear setting with "Pad" feature to -10dB as that is all I can think of. Just because it is the exact 10 dB drop and that is usually what you can select for most gear (microphones) particularly and interfaces as a standard pad dB reduction or +4 dB gain. I would check the whole chain and see if any of the pieces have been set to "Pad setting -10" and if so just put it back to +4 or + 10 or whatever is the option. Best Of Luck Christopher
Best Regards Christopher #thestruggleisreal ————————————— South Side Music Group WEBHOME ————————————— |
Setting Output to -10dB - How? | Patill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-13-2011 07:41 PM |
Please Help with Setting up Mixer for Band Compression | tonesponge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-15-2010 12:15 PM |
How do I know if I'm -10db or +4db? | [email protected] | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-18-2010 03:40 AM |
Bass parallel compression setting up of tracks | Stoneroses63 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-10-2006 10:57 AM |
BTD and loss of Compression? | Eddie K. wannabe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 04-30-2002 11:36 PM |
