Old 01-06-2010, 03:29 AM
joshuadanger joshuadanger is offline
Exclamation MIDI and Instrument Tracks won't play back
I have two instrument tracks that were working normally. I played on note on my AKAI controller and the level spiked. Now, neither instrument track will play back, nor will the keyboard work for those channels. It still works for other channels in the same session.
I can still see all the midi information in the tracks not working. Any thoughts?
Thanks
www.joshuadanger.com
Old 01-06-2010, 05:21 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Re: MIDI and Instrument Tracks won't play back
I have similar things happen in the past. What I did was simply reboot PT and turn my keyboard off and back on. That always worked to clear out any MIDI glitches. If the problem persists after doing that, then you'll need to isolate it...but I'm guessing you won't need to.
Old 01-06-2010, 06:08 PM
I tried this a few times and still not working. Everything is visible, just nothing playing back.
Joshua Danger
Old 01-06-2010, 07:08 PM
flommer flommer is offline
Try a new session
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 01-07-2010, 05:02 AM
DonaldM's Avatar
Yeah, I agree with Flommer. A couple of times I've had to do exactly that...just create a new session. Another possibility, just create new instrument track, re-copy the midi data, reinstatiate your VI, and try that.
Just a thought, but where is your audio output from the instruments going? Did you route them to an buss, for example?
Old 01-07-2010, 01:39 PM
I've included a snapshot of the tracks not working. As of now, each track has it's own instance of Xpand on it. I'll try the other idea of copy/paste to a new instrument track..
/Users/joshhuslig/Desktop/Screen shot 2010-01-07 at 1.37.04 PM.png
Joshua Danger
Old 01-07-2010, 01:40 PM
guess that didn't show up did it? hmm
Joshua Danger
Old 01-07-2010, 01:47 PM
You have to use photobucket or similar to post screenshots..
Did you try in a new session? Sometimes MIDI gets corrupted and there is noting you can do.
If the problem still happens in a new session then there are other things that could be the issue..
Pro tools 8/instrument play back problem! BtotheZ26 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-01-2011 01:58 PM
Recorded MIDI/Instrument track seen but won't play back ragbor MIDI 12 04-23-2011 09:16 AM
PT8 - instrument tracks won't play when made active conjure.one Pro Tools TDM Systems (Mac) 4 06-04-2009 01:30 PM
can't play back 8 tracks mix using 1.25 mac os 9.2 Brandonx1 Pro Tools TDM Systems (Mac) 0 08-04-2004 02:42 PM
MIDI Tracks play back through stereo not MBOX why? gbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-08-2003 10:22 AM
