How to record a looping Midi Trk to an Audio Trk
I have created a 4 bar Midi beat in a Midi track in PT 7 and I'm trying to record it to an audio track having it continually loop the 4 bars so the audio track will just keep on recording till I stop playback.
For some reason when I go to record the Midi track to the audio track with Loop playback on the recording will stop right after the 4 bars plays just the one pass. I cannot get it to continue to loop when recording it to audio. Any suggestions to make this work?
(PT12.4- Win7Pro - mboxpro3 -Axiom25- Maschine) |
Re: How to record a looping Midi Trk to an Audio Trk
Try 'Loop Record' and drag the regions from the Bin in Shuffle mode or print one pass and use 'Loop' and enter the amount of loops you require.
filosofem
Aaron Mulqueen - 001 HD Native |
Thanks for your response...I know about the Region - Loop method...but is there any way to have the midi track just continually loop until I stop it while I'm recording it to an Audio track?
Not 100% sure, but I don't think that that method of recording is possible.
filosofem
There's got to be a way/solution
yeah, the solution is to record your four bar beat to audio, and loop the audio. What is so complicated about that? What exactly do you want from your DAW?
no offence, bro, I am just curious as far as what you want. The converting to audio and looping sounds pretty easy, no?
Having said it could be the only way to do such a thing in PT LE, if you know another program that can do this even easier (another assumption, only based on the fact that if you have the idea, chances are alot of other people do too), use that program and import the final region to Pro Tools. Or really, go the easy route. Why you'd want to make it even harder is beyond me. You agree the suggestion is easy. Be happy and run with what works!
Kryst |
help me record MIDI from audio!! | amoretam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-14-2010 08:00 PM |
record MIDI as audio | onimic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-15-2005 09:09 AM |
Can't record MIDI to audio anymore | sricabla | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-05-2005 10:39 AM |
How to Record MIDI as Audio? | BalSagoth6 | MIDI | 4 | 12-31-2004 11:46 AM |
looping midi - recording audio | mecanoiz | Tips & Tricks | 3 | 07-16-2004 02:53 AM |
