Is this workable
Hi Pro Mixing Community,
If I used a Cisco SG300-28PP Gigabit PoE Managed Switch along with the Avid Control app could I run them directly from an Apple M1 Laptop. Could I connect the Cisco via my iPhone or do I need a separate Wifi router I would also like to have EuControl connected to an Avid S3 and ProTools Ultimate. Regards |
Re: Is this workable
The iphone needs to be on the same network as the Mac for Avid Control to connect. It doesn't have to be the same one as the S3/Dock though which can be connected through that switch to the Mac. Either you need A WiFi router as well or if there's a wired ethernet adapter for an iPhone?
To Eddie,
Just trying to work the following out Network Adaptor Error Multiple network adaptors on same subnet detected. Multiple adaptors on the same subnet may cause random issues with EuControl and other applications. Disable all adaptors except one to avoid any networking problems. Network adaptors found: Belkin USB-C Lan USB 10/100 LAN Any ideas? Regards |
Both those network adapters are either connected to the same network or they both don't have a router. (only one can be without a router) or the IP address range is set the same for both.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
How Far Back To Go for Workable MIDI | Steve@ZooWest | Pro Tools 12 | 7 | 05-15-2016 01:09 AM |
Is UAD workable in PTLE? | req06 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-07-2008 05:33 AM |
is this a workable setup??? | Gilley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-25-2006 10:36 PM |
Pro tools 6.4 with OSX tiger, is this workable? | sukks2bu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-31-2006 09:57 AM |
are they workable on Macs & PCs? | taycw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-20-2001 02:09 AM |
