Closed Thread
  #121
Old 12-27-2022, 01:09 PM
off the wall's Avatar
off the wall off the wall is offline
Default Re: Pro Tools Public Beta: December 2022
Originally Posted by pm mastering studio View Post
I am a bit disappointed the ICON Control surfaces wont be able to connect to an silicon-Native version of ProTools Ultimate. Not sure when AVID will completely change to Native (and ditch Mac-Intel completely) but one can only assume this is a logical way they will go for future development (pretty sure they will not continue to develop 3 different OS's (Win- MACOS and Silicon Mac))
This means I have to invest heavily into a new console if I want to change my MacPro into a new M(x)-silicon enabled MAC computer ! I'm sorry but don't have that 60K investment lay-ing around these days to make a switch to S4 or even S6 :-(
What makes it even worse is that WINDOWS computers will still be able to use the Control surface (until AVID breaks that connection offcourse) and recieve updates.
Do I have to switch to Windows again ? MAC has brought me so much joy ;-)
Although I understand the switch to Silicon Native. AVID will lose a big part of there clients who still use a Command/ICON control surface.
I do urge AVID to consider updating there strategy and transfer the Command/icon interface into the new Native system.
PLEASE - PLEASE - PLEASE
I have the same concern with my C|24. I hoping Neyrinck might be the answer when that time comes.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
  #122
Old 12-27-2022, 01:11 PM
Ben Jenssen's Avatar
I'm not installing this. Yet.
My current setup is 100% solid for what I need.
The single one thing I could be curious about is the added performance w/native, but even that I expect not to be very significant.
Couple of things I wonder about:
1. How are you approaching this?
Are you installing right on top of your current version, doing the rename old version trick to keep both, or installing on a separate system?
2. About co-existing versions of PT. How are prefs and other files handled? Seamlessly, or what? What about PT rosetta vs native, settings and 'background' files are shared or what?
I guess Pete Gates, maker of PT Prefs 2 app, will be looking into this soon enough.
  #123
Actionmusic Actionmusic is offline
Originally Posted by Raphaeld View Post
I'm only using VintageVerb 2.2.8.
When I go into Macintosh HD/Library/Application Support/Avid/Audio/Plug-Ins/ValhallaVintageVerb.aaxplugin the version number is 2.2.8 which is Apple Silicon compatible. I think there's a bug in this beta.
sorry I missed this as running a blank test session, vintage verb is the only one that doesn't appear (does not even appear on plug list) , will mail them thanks
  #124
Old 12-27-2022, 01:14 PM
2022.12 is a Universal Binary. You just toggle the "Run under Rosetta" check in the apps Get Into in the Finder. It is one app.
  #125
Old 12-27-2022, 01:26 PM
I understand this.
Perhaps read my post again?
Thanks for trying, though.
  #126
Old 12-27-2022, 01:32 PM
Pro Tools Operating System Compatibility Chart
Well, well, well.
It supports macOS back to Mohave!
  #127
I understand this.
Perhaps you were referring to PT 2022.10 and 2022.12 but your initial question inferred you were talking about the native vs. the Intel variants of PT 2022.12.
This in your original post is ambiguous.
"1. How are you approaching this?
Are you installing right on top of your current version, doing the rename old version trick to keep both, or installing on a separate system?"
  #128
Old 12-27-2022, 01:36 PM
M2E M2E is offline
UPDATE
Well, I loaded all the updates that say they're native for Apple Silicon but 2022.12 doesn't believe it. After installing all the updates and restarting PT still doesn't show FabFilter (for example) as an available plug-in.
I've had the same issue. I updated and ran Pro Tools in Native, and most of my plugins in this test setup didn't run on the Native version. Run's fine in Rosseta though.
Marc
New System: Macbook Pro M1 Max/16 gigs of Ram/Monterey/3 UAD Quad Satellites/2 PCIe Quad UAD cards/Waves Digigrid/Antelope Zen Pro/OWC 3 Slot Thunderbolt PCIe unit/Over 1400 plugins (Beta Tester for 15 different companies)
YouTube Channel https://www.youtube.com/watch?v=HaZYp2wNomc
  #129
Old 12-27-2022, 01:39 PM
Just forget it. I think most people are aware what a 'universal binary' is. That question was more about the fact that this is a 'public beta'. See the release notes for the list of what is NOT working in 22.12.
  #130
Old 12-27-2022, 01:43 PM
grayter1 grayter1 is offline
I'm doing the renaming thing and running both on the same system, as I've done for almost every update for years.
Not sure how pref's are being handled under the hood, but things seem to be in place for both the native and rosetta versions.
tg
Mac Studio (2022) M1 MAX / 64GB / 2TB HD / macOS Ventura 13.6.5 / RME BabyFace Pro FS / SSL UF8 + UF1 + UC1 / Roland SYSTEM 8 / Kontrol S61 mk3 / Pro Tools Studio 2024.3 / Nuendo 13 / Reaper 7 / Komplete 14 / Omnisphere / Keyscape / Trilian / V Collection X
Closed Thread
I have to December 2022 to leave ProTools. Recommendations? TimothyJohn General Discussion 11 06-09-2022 04:25 PM
New Axiom Pro HyperControl personality for Pro Tools 8.0.4 released to Public Beta Jared MIDI 0 11-10-2010 09:45 AM
-9093 error with Pro Tools LE 8.0.3 Public Beta & Windows 7 Sountrak_IT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-23-2009 11:34 AM
Pro Tools 8 64bit public beta Zeff Pro Tools M-Powered (Win) 20 08-17-2009 10:13 AM
OS X Public beta MAri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-13-2000 06:29 PM
