Cleaning up multiple tracks at the same time?
I'm working on an orchestral recording and there are a few noises here and there. When I work in Sequoia I can use the built in Spectral Cleaning to find and kill a noise on one track and it then applies the same process to the other tracks. Is there really no better solution than to manually RX every track in a 24 channel recording?
I just wanna do engineering... (as opposed to make music :/ ) |
Re: Cleaning up multiple tracks at the same time?
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
I do a lot of live show mixing and whenever there's a bit of feedback, I wait until the mix is done and then RX the 2 track. Why make it harder than it needs to be?
Thanks for your replies.
It is possible to use RX declicker, declipper et cetera as batch processing but in this case I need the spectral cleaning which I don't think is possible to use this way. It might be better to do it on the mix but RX doesn't handle surround files so it will take some trickery. Also in the best of worlds I like to RX things and then let things like reverb smooth things out a bit.
Both very good reasons!! Good luck.
How to stop multiple instrument tracks being triggered at the same time | gutterfly | macOS | 1 | 12-07-2012 04:45 AM |
Copying/Pasting Multiple Tracks at a Time | KMAN385 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-30-2007 02:23 PM |
time for a bath!! cleaning a procontrol? | ChannelZero | ProControl, Control|24, Command|8 | 1 | 01-22-2007 07:06 AM |
time compression on multiple tracks | KingTor | Pro Tools TDM Systems (Mac) | 13 | 04-04-2000 02:07 PM |
Time comp/exp over multiple tracks-need help | CCash | Tips & Tricks | 9 | 03-03-2000 03:33 AM |
