Digi 002 and SMPTE or other timecode?
I'm considering getting started with a home studio, and I'm seriously considering pairing the Digi 002 with my G4 tower. However, I may be editing the audio for a few independent films, as well as the music I normally do. The audio is all on DAT tapes, and I need to be able to get it into the computer with timecode intact if at all possible. Is there any way to do this with the Digi 002? If not, does anyone know of a comparable piece of hardware that can do it? |
Re: Digi 002 and SMPTE or other timecode?
motu 2408 mk3 it has a direct sync out.you cant use it with pt though!
Which DAT machine? Does it output LTC? If so get any MIDI interface that will input LTC and sync protools to that for your location, and transfer the actual audio as SPDIF to get clocking info and ensure that you are resolved.
If it is just absolute time then there really isn't a way to maintain that 'time code' except by cueing up Protools and hitting record at the proper time, then figuring out how far off you where. If you are transferring digitally it will always be off by the same amount on any material transfered at a single time. ( I hope this is not the case, but I bring it up just in case . . . [img]images/icons/grin.gif[/img] )
Shawn Parr Muskrat Studios |
Pro Tools LE (the cheapo version of Pro Tools that comes with digi001, 002, and Mbox) doesn't support SMPTE.
there's various ways to work around this for various different purposes. recently i needed to upload some tracks that were recorded to several ADATs, linked by SMPTE, so i had the guy who recorded them record a snare-drum beat at the beginning of each tape (with the tapes synched) so that i could group the tracks and match them up visually. for my purposes, this worked fine. but if you're going to do a lot of sound-to-picture work that relies upon SMPTE, you'd be better off with a high-end PT system (if you can afford one) or with one of the other audio/sequencing programs that offer SMPTE capability. |
i read somewhere in an recent sound on sound intervieuw about a guy who uses an smpte to mtc coverter to sync protools to video tape. i believe it was a box from jlcooper.
You have many SMPTE to MTC converter and for that I recommand you the Motu MicroExpress who can lock MTC to SMPTE. But that give you location time but you need something to synch precisely audio to video, for that you need something like Rosendahl Nanosynch or MOTU Timepiece who give you from video wordclock (unusable by Digi001 and 002) and SPDIF(usable). And after you choose SPDIF in place of internal for your clocking.
But PTLE dont give you SMPTE on counters, tracks etc., not very friendly. Personaly I changed to DigitalPerformer: SMPTE, 5.1, no tracks limitation and any hardware you want |
If you need to sync to an analog source than the MOTU DTP is your best bet as it will also generate your digital clock off of LTC. SMPTE = positional sync Clock = timing sync Resolved = positional sync + timing sync
Okay, so if a MIDI device doing LTC/MTC is all I need, along with SPDIF, then is the 002 by itself adequate? It has MIDI built in, so can it handle this?
You can certainly synch to picture given a MTC converter and SPDIF.. the software however will not let you "Spot" to a SMPTE location.
If you don't need to have a SMPTE timeline, then you'll be okay. BTW - I personally like to use a card like the DC30 Plus and have the picture digitized.. but for editing I find having a SMPTE timeline when working with picture important. Rail
Generating SMPTE Timecode in PT | Adam Ings | General Discussion | 2 | 11-24-2007 02:25 PM |
SMPTE Timecode via RS-422? | rexdigital | Pro Tools TDM Systems (Mac) | 2 | 04-12-2007 09:08 AM |
Timecode/SMPTE to track changes? | Mark Reis | Post - Surround - Video | 8 | 03-11-2004 12:38 PM |
smpte timecode to timecode dat from PT LE 6.2.2 | shake | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 01-21-2004 01:16 PM |
SMPTE - Timecode ? | AcornSound | General Discussion | 2 | 03-24-2000 06:46 AM |
