PT LE8 Windows hangs on startup
Hi
I recently had my PC formatted & updated and reinstalled all software but cannot launch Pro Tools. I get this error message: "Could not complete your request because Access Violation occured, unable to read location: 0x00000000 at address: 0x00000000 in module: ProToolsLE.exe" It always hangs at the same plug-in every time: "bombfactory BF76 (Automap). dpm I am running LE 8.0.3 (and was prior to my problems) on Windows XP SP3. I have MBox 2 Factory. I have removed IE8, changed USB ports on the PC, tried updated drivers and uninstalled and re-installed. I have now been 4 months without PT and am having withdrawls. Any help is appreciated. Regards Rich Here is my Sandra report: SiSoftware Sandra System Host Name : R-91A01A3E57E74 User : Owner Workgroup : MSHOME Processor Model : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Speed : 2.40GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Internal Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, Inclusive, 64 byte line size L2 On-board Cache : 2x 4MB, ECC, Synchronous, ATC, 16-way, Inclusive, 64 byte line size, 2 threads sharing System Mainboard : Intel Corporation DP965LT Bus(es) : ISA PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : 1 Processor(s) Multi-Processor Advanced PIC (APIC) : Yes System BIOS : AT/AT COMPATIBLE INTEL - 6b6 Total Memory : 3.25GB Chipset 1 Model : Intel P965/G965 Memory Controller Hub Front Side Bus Speed : 4x 266MHz (1.06GHz) Video System Monitor/Panel : Plug and Play Monitor Adapter : NVIDIA GeForce 8400 GS Physical Storage Devices ST380815AS 80GB (SATA150, NCQ, 8MB Cache) : 74.53GB (C:) (D:) ST3250410AS 250GB (SATA150, NCQ, 16MB Cache) : 232.89GB (E:) ST330062 2A 300GB (USB) : 279.46GB (G:) HL-DT-ST DVDRAM GH20LS10 (SATA150, 48x CD-R, 48x CD-W, 6x DVD-R, 6x DVD-W, 2MB Cache) : N/A (F:) Logical Storage Devices Hard Disk (C:) : 39.06GB (3.56GB, 9% Free Space) (NTFS) @ ST380815AS 80GB (SATA150, NCQ, 8MB Cache) Hard Disk (D:) : 35.46GB (35.40GB, 100% Free Space) (NTFS) @ ST380815AS 80GB (SATA150, NCQ, 8MB Cache) Hard Disk (E:) : 232.88GB (178.13GB, 76% Free Space) (NTFS) @ ST3250410AS 250GB (SATA150, NCQ, 16MB Cache) CD-ROM/DVD (F:) : N/A @ HL-DT-ST DVDRAM GH20LS10 (SATA150, 48x CD-R, 48x CD-W, 6x DVD-R, 6x DVD-W, 2MB Cache) New Volume (G:) : 279.46GB (29.43GB, 11% Free Space) (NTFS) @ ST330062 2A 300GB (USB) Peripherals Serial/Parallel Port(s) : 1 COM / 1 LPT USB Controller/Hub : Intel(R) ICH8 Family USB Universal Host Controller - 2830 USB Controller/Hub : Intel(R) ICH8 Family USB Universal Host Controller - 2831 USB Controller/Hub : Intel(R) ICH8 Family USB Universal Host Controller - 2832 USB Controller/Hub : Intel(R) ICH8 Family USB Universal Host Controller - 2834 USB Controller/Hub : Intel(R) ICH8 Family USB Universal Host Controller - 2835 USB Controller/Hub : Intel(R) ICH8 Family USB2 Enhanced Host Controller - 2836 USB Controller/Hub : Intel(R) ICH8 Family USB2 Enhanced Host Controller - 283A USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Mass Storage Device USB Controller/Hub : USB Composite Device USB Controller/Hub : Digidesign Mbox 2 Firmware Updater FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : HID-compliant mouse Human Interface : HID-compliant device Human Interface : USB Human Interface Device Human Interface : USB Human Interface Device Printers and Faxes Model : Microsoft XPS Document Writer Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP (2002) Home 5.01.2600 (Service Pack 3) Platform Compliance : Win32 x86 Network Services Adapter : Intel(R) 82566DC Gigabit Network Connection |
Re: PT LE8 Windows hangs on startup
Make sure you have the latest PACE drivers from www.paceap.com
The automap thing is a bit odd... Are you using a Novation controller with Automap? Since you are on XP, would you please run the Tech Support utility from the Tech Support Folder and generate a plugin list for us? That will definitely make things a whole lot easier to diagnose.
Thanks spkguitar.
I have updated the latest PACE drivers to no avail. Yep, using a Novation SL25 controller with Automap. Tried the Tech Support utility which I downloaded to disc but it would not run on my PT PC. I got the error: "Windows cannot access the specified device, path, or file. You may not have the appropriate permissions to access the item". Is this maybe an administration issue? I have also tried to remove Service Pack 3 but cannot find it on the Control Panel. I don't have much confidence in the guy who formatted my PC. I am worried that he may have deleated some part of Windows. |
Thanks for your help. I managed to get the Tech Support Utility working (it had corrupted when I extracted the files) and it solved my problem - so far. I have PT 8 up and running after 4 months of downtime so won't be seeing much of the world for a few days. |
New PT 10 upgrade won't complete startup: hangs on "Restoring Windows" | georgelegeriii | Pro Tools TDM Systems (Mac) | 0 | 11-19-2012 12:14 PM |
HELP! PT Hangs Up On StartUp. | Steve@ZooWest | Pro Tools TDM Systems (Mac) | 5 | 05-22-2010 12:15 AM |
PT8 hangs on startup looking for Waveshell | Luuu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-22-2010 12:07 PM |
001 hangs on Midi startup | rotrabhabr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-05-2003 04:32 PM |
5.0.1/G3 B&W Hangs @ StartUp!! | DFatz1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 07-17-2000 01:07 AM |
