Playback stops at end of timeline selection?
Is it normal that playback stops at end of a timeline selection, I seem to recall that PT7 didn't do this. I find it really annoying as a lot of times I like to work on a loop then play from before the loop until after the loop, but then go back to the loop. It seems like now I have to clear the time line selection to do this. then reselect it again, (drives me almost as nuts as the fact you have to stop playback to turn page scrolling on and of, and that there no key command for it either, better stop there or I'll be here all night!!!). Anyway, back to the point in question, is there any option to make playback independent of the timeline selection? I can't see one.
Any help would be much appreciated. Thanks |
Re: Playback stops at end of timeline selection?
Thanks, I know could work that way, but funnily enough pre roll doesn't work on my system, any suggestions on that? I'm pretty sure that it's only since PT8 that it's behaved this way, I've been using Protools for a few years now, I wouldn't claim to be an expert, but I know my way around it pretty well.. I don't have to do that in Logic, Cubase, Live or even Reaper all of which I use on a regular basis depending on the job, so I just find it a little annoying.
Anyway thanks for the tip. |
Have you unlinked the Time Line and Edit selection by any chance?
Cheers,
Grr.. Link Timeline Edit Track Edit Timeline Selection confusion | deepfrequencies | macOS | 3 | 02-06-2014 02:40 PM |
Playing back part of a selection without affecting timeline/selection | jschmidtiii | macOS | 2 | 05-11-2013 01:05 PM |
PTLE8 Playback stops at end of time selection? | Blank Frank | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 02-25-2009 08:55 PM |
edit selection disappears when playback stops. what'd I do?! | EricWillhelm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-29-2007 10:25 AM |
How do you keep selection after playback stops? | who | Pro Tools TDM Systems (Mac) | 5 | 04-07-2001 04:14 PM |
