Old 05-25-2010, 07:24 AM
MCallan713 MCallan713 is offline
Default Win 7, OWC external HDD, not a valid audio volume...
Hey guys, so I received my OWC Muercury Elite-AL Pro external HDD 750GB 32 cache yesterday so I can properly record with Pro Tools LE. I had a difficult time setting it up since Im not too computer savvy but have finally got the correct GB amount and the HDD showing on my computer.
When I went to record a session in PT I got the message that said not a valid audio volume, if i could to change it to "R" for record. So I followed what was told on this site went to the workspace and under A was a T and under V was an R. I went to change the T to an R under A and it says that it
"cannot be designated as an Audio Record volume because it is not a valid audio volume."
My drive shows up as BASIC with NTFS. I know alot of you dont use win 7 with PT yet but it is all i have wondering if anyone has any info to fix this problem. any help is appreciated guys thank you
here is my sandra report:
Processor
Model : Intel(R) Core(TM)2 Duo CPU T6600 @ 2.20GHz
Speed : 2.2GHz
Cores per Processor : 2 Unit(s)
Threads per Core : 1 Unit(s)
Type : Mobile, Dual-Core
Integrated Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 2MB, ECC, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing
Computer
Platform Compliance : Intel Centrino Mobile Technology
Mainboard : Sony VAIO
BIOS : AMI R2010Y4 11/13/2009
Bus(es) : PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 3.84GB DDR3 SO-DIMM
Chipset
Model : Sony GM45 Mobile Controller Hub
Front Side Bus Speed : 4x 199MHz (796MHz)
Total Memory : 4GB DDR3 SO-DIMM
Shared Memory : 128MB
Memory Bus Speed : 2x 398MHz (796MHz)
Memory Module(s)
Memory Module : PQI MECEG523PA0102 2GB DDR2 SO-DIMM PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3)
Video System
Video Adapter : Mobile Intel(R) 4 Series Express Chipset Family (10 SM4.0, 128MB DDR3, Integrated Graphics)
Graphics Processor
Storage Devices
TOSHIBA MK3263GSX (320GB, SATA150, 2.5", 5400rpm, NCQ, 8MB Cache) : 298GB (C:)
RICOH R5C822 : N/A (E:)
RICOH R5C592 : N/A (F:)
HL-DT-ST DVDRAM GT20N (SATA150, DVD+-RW, CD-RW, 1MB Cache) : 3GB (G:)
Logical Storage Devices
System Reserved : 100MB (NTFS)
Hard Disk (C:) : 287GB (NTFS) @ TOSHIBA MK3263GSX (320GB, SATA150, 2.5", 5400rpm, NCQ, 8MB Cache)
Recovery : 11GB (NTFS)
Removable Drive (E:) : N/A @ RICOH R5C822
Removable Drive (F:) : N/A @ RICOH R5C592
BUILD (G:) : 3GB (UDF) @ HL-DT-ST DVDRAM GT20N (SATA150, DVD+-RW, CD-RW, 1MB Cache)
Peripherals
LPC Hub Controller 1 : Sony (ICH9M) LPC Interface Controller
Audio Device : Sony (ICH9) HD Audio Controller
Audio Codec : Realtek Semiconductor 262 High Definition Audio
Disk Controller : Sony (ICH9) Mobile SATA AHCI Controller
USB Controller 1 : Sony (ICH9) USB Universal Host Controller
USB Controller 2 : Sony (ICH9) USB Universal Host Controller
USB Controller 3 : Sony (ICH9) USB Universal Host Controller
USB Controller 4 : Sony (ICH9) USB2 Enhanced Host Controller
USB Controller 5 : Sony (ICH9) USB Universal Host Controller
USB Controller 6 : Sony (ICH9) USB Universal Host Controller
USB Controller 7 : Sony (ICH9) USB Universal Host Controller
USB Controller 8 : Sony (ICH9) USB2 Enhanced Host Controller
FireWire/1394 Controller 1 : Sony R5C832 IEEE-1394 Controller
SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Peripherals
Media Player : ()
Media Player : ()
Network Services
Network Adapter : Marvell Yukon 88E8057 PCI-E Gigabit Ethernet Controller
Wireless Adapter 1 : Atheros AR9285 Wireless Network Adapter (802.11g (ERP), WEP n-bit, 54Mbps)
Power Management
Mains (AC) Line Status : On-Line
Battery No 1 : 95%
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7600
Platform Compliance : x64
Windows Experience Index
Current System : 3.4
Old 05-25-2010, 07:54 AM
Default Re: Win 7, OWC external HDD, not a valid audio volume...
please help,i have had this since march and have not been able to "officially" record correctly becaus i am new to this and am trying to figure it out for myself but this is getting frustrating spending money and money and not getting results, not any of your faults, just sucks this product needs so much extra to make it work properly
Old 05-25-2010, 08:26 AM
spkguitar's Avatar
Your external drive is not listed in your sandra report.
It is very important to run your sandra report on your computer exactly as it is when running Pro Tools.
You are running windows 7 64bit; are you using the beta drivers? (you should be).
Reports in another Windows 7 thread state that uninstalling, rebooting and re-installing the driver solved a similar problem.
Old 05-25-2010, 10:06 AM
DigiTechSupt's Avatar
You should also format any new drive before using it.
Here's a link to a quick video on how to do that:
http://www.youtube.com/watch?v=2hbeUwk3s6c&feature=player_embedded#!
Avid Audio Tech Support
Support FAQ
Old 05-25-2010, 03:05 PM
Thanks, Im at work on break now so cant watch the video, but I will check it out even though Im fairly sure that I already formatted it. Over the phone with OWC this morning they helped me out, it matches exactly what my C: drive says basic, ntfs, so Idk, I will do some more searching later, if anyone else has any info its appreciated, thanks again you guys!
Old 05-25-2010, 07:42 PM
Here is my updated SANDRA report
SiSoftware Sandra
System
Host Name : MATTCALLAN-VAIO
User : Matt Callan
Workgroup : WORKGROUP
Processor
Speed : 2.19GHz
Type : Dual-Core
Internal Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, Inclusive, 64 byte line size
L2 On-board Cache : 2MB, ECC, Synchronous, ATC, 8-way, Inclusive, 64 byte line size, 2 threads sharing
System
System : Sony Corporation VGN-NW320F
Mainboard : Sony Corporation VAIO
Bus(es) : PCI PCIe USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : American Megatrends Inc. 20.10
Chipset 1
Model : Sony ??? (2A40)
Video System
Monitor/Panel : Generic PnP Monitor
Imaging Device : Sony Visual Communication Camera
Physical Storage Devices
TOSHIBA MK3263GSX 320GB (SATA150, NCQ, 8MB Cache) : 298.09GB (C:)
Ext Hard Disk 750GB (FireWire/1394, NCQ) : 698.64GB (D:)
HL-DT-ST DVDRAM GT20N (ATAPI, 24x CD-R, 24x CD-W, 3x DVD-R, 3x DVD-W, 1MB Cache) : N/A (G:)
System Reserved : 100.00MB (71.65MB, 72% Free Space) (NTFS)
R (D:) : 698.44GB (698.33GB, 100% Free Space) (NTFS) @ Ext Hard Disk 750GB (FireWire/1394, NCQ)
Hard Disk (C:) : 286.99GB (239.36GB, 83% Free Space) (NTFS) @ TOSHIBA MK3263GSX 320GB (SATA150, NCQ, 8MB Cache)
Recovery : 11.00GB (831.31MB, 7% Free Space) (NTFS)
CD-ROM/DVD (G:) : N/A @ HL-DT-ST DVDRAM GT20N (ATAPI, 24x CD-R, 24x CD-W, 3x DVD-R, 3x DVD-W, 812kB Cache)
Peripherals
USB Controller/Hub : Intel(R) ICH9 Family USB Universal Host Controller - 2934
USB Controller/Hub : Intel(R) ICH9 Family USB Universal Host Controller - 2935
USB Controller/Hub : Intel(R) ICH9 Family USB Universal Host Controller - 2936
USB Controller/Hub : Intel(R) ICH9 Family USB Universal Host Controller - 2937
USB Controller/Hub : Intel(R) ICH9 Family USB Universal Host Controller - 2938
USB Controller/Hub : Intel(R) ICH9 Family USB Universal Host Controller - 2939
USB Controller/Hub : Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293A
USB Controller/Hub : Intel(R) ICH9 Family USB2 Enhanced Host Controller - 293C
USB Controller/Hub : USB Root Hub
USB Controller/Hub : USB Composite Device
USB Controller/Hub : Digidesign Mbox 2 Firmware Updater
FireWire/1394 Controller/Hub : Ricoh 1394 OHCI Compliant Host Controller
Keyboard : Standard PS/2 Keyboard
Mouse : Alps Pointing-device for VAIO
Human Interface : Sony Firmware Extension Parser Device
Printers and Faxes
Model : Fax
Model : Canon Inkjet iP2600 series
Power Management
Battery No 1 : 100%
Operating System(s)
Windows System : Microsoft Windows Vista Home Media Center 6.01.7600
Platform Compliance : Win64 x64
Network Services
Adapter : Atheros AR9285 Wireless Network Adapter
Old 05-25-2010, 07:59 PM
j4callen j4callen is offline
I went through this same frustrating process.
Make sure you remove the GUID Partitioning Scheme. The instructions on how to do so are included with the drive. It says you shouldn't have to for Win 7, but I definitely had to before the drive was recognized as anything other than transfer only.
Good luck!
Old 05-25-2010, 08:17 PM
TOM@METRO's Avatar
Your new Sandra report shows Vista Media Center 64 bit. I doubt this will ever fly.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 05-25-2010, 08:23 PM
Im having a hard time finding anything on removing the GUID partition scheme. Do you remember at all on how to do that?
Whats wrong with the Vista Media Center 64 bit? I have recorded with this laptop on its internal hard drive fine before I bought this external drive, but everyone on this board kept saying I need one, and that it may help stop the HW Buffer Size error I was getting sometimes.
The exact message I get when I try to change Audio (T)ransfer to (R)ecord is:
"cannot be designated as an Audio Record volume because it is not a valid volume."
Old 05-25-2010, 09:08 PM
dave911's Avatar
dave911 dave911 is offline
go to windows "computer management/disk management" and search for "convert GDI"
You need to move everything off the disk first.
cannot be designated as an Audio Record volume because it is not a valid audio volume Gav_Russell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-15-2016 03:52 PM
Cannot be designated as an Audio Record Volume because it is not a valid Audio Volume soloavenger macOS 7 02-15-2016 03:49 PM
New supported external drive "not a valid audio volume" j4callen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-12-2009 08:53 PM
Not a Valid Audio Volume Kenneth Andrews 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-05-2006 11:36 PM
Not a Valid Audio Volume?? silence2-38554 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 06-06-2006 05:32 PM
