Old 04-12-2017, 11:53 PM
falcondoodle falcondoodle is offline
Default pro tools slow performance renders it unusable.
I have been using pro tools for about 6 years now. I've had my share of issues with installing it and getting things to work through compatibility issues. So many so that i have a midi controller that i need to use, but rather than spend the hours trying to get it running, i just work around it. Today i launched a new project from a template, so that i could start to get some work done as usual. I found that when i opened the midi editor, my mouse was jumping around the screen as if i had set my framerate to 3fps. Super slow when i try to do anything, meanwhile no changes have been made to my PC, and everything else works great. im not even hitting 20% usage of RAM or CPU. when i click and drag the mouse to highlight sections of the project, it takes a minute to happen, and if i highlight a note, it takes even longer (around 5 seconds), and then the note is played. I couldn't find a solution for this anywhere. I searched and some people were saying that it might be having a CD in my CD drive. i ejected it and sure enough, there was one in there, so i thought i had it fixed. Didn't work. I trashed my preferences. Installed PT 10 to see if it was happening there, and it is. Please i would appreciate any help or suggestion, i am so desperate at this point.
Old 04-13-2017, 04:26 AM
Default Re: pro tools slow performance renders it unusable.
The cd in drive is but one impediment to good performance with Windows. Also make sure that the floppy drive is disabled from inside Windows BIOS - you may not have a drive but Windows doesn't know that and still provides for one. Also have you done all the system optimizations Avid and others recommend? Back in the day BlackViper used to have a website that had a ton of info on Windows optimizations.
Do you have a separate drive for PT to record to?
Do you use samples and if so are they on a separate drive?
What is the speed of your system drive (or is it an ssd)?
Jack
QAPLA!
Old 04-13-2017, 04:29 AM
idk what optimizations you're talking about, but i looked everywhere in my bios and could not find a floppy or legacy drive to disable. saw that suggestion in a lot of videos, but all of the videos had an old ass bios.
Old 04-13-2017, 04:45 AM
There are various optimizations that can be done on any machine especially on a bloatware-prone Windows PC. You can search here for them, the Avid site or the web itself and for that Google is your friend. The age of the BIOS doesn't matter.
But you haven't answered the questions I asked about the drives in your setup. Answering things like this piece-meal isn't helping you to get a good and quick answer.
Jack
QAPLA!
Old 04-13-2017, 10:52 AM
pro tools is on system drive and recording to a seperate 7200 rpm drive.
sometimes i use samples, but it happens on the project i just created with nothing but 3 midi notes in it. samples are kepts on the same 7200
SSD system drive.
Old 04-13-2017, 12:51 PM
I have now done all of the optimizations from the avid website, and the problem persists.
Man this sucks... it has worked perfects for years now...
Old 04-13-2017, 02:01 PM
panamajack's Avatar
panamajack panamajack is offline
. . . no changes have been made to my PC, . . . when i click and drag the mouse to highlight sections of the project, it takes a minute to happen, and if i highlight a note, it takes even longer (around 5 seconds), and then the note is played. . .
My first inclination would be to use control panel and click on device manager. If any of your hardware shows a yellow exclamation point, there is some sort of conflict.
An interrupt conflict will also create that sort of weird mouse response. If you have a PC mouse, change to a USB mouse, or vice versa.
If you just added a MIDI controller of some sort, it may need a device driver to work properly: it may not be Plug and Play.
OMNI, HD Native PCIe, 192 I/O, 96 I/O, 11R. PT Ultimate 2024, 2022, 2019, TDM, HD 11, 10, 9, 8, 7.4. Mac Pro 2019 (Sonoma, Monterey), 2012, 2010 (Catalina)
Old 04-13-2017, 02:34 PM
SSD system drive.
There is no such thing as a 7200 SSD drive. 7200 is a spec for a spinning drive and it's the speed of rotation of the internal platter(s). SSD has no moving parts.
Are you by any chance trying to surf the net through a wireless connection while working in PT? That'll muck things up big time.
What other crud do you have going on at the same time PT is trying to run? Do you have a virus scanner running?
Jack
QAPLA!
Old 04-13-2017, 04:57 PM
i've shut everything down and disabled the network adapter to check if it was cpu usages or otherwise. my system drive is SSD and the drive i record to and have samples on is a 7200 rpm 1 TB drive.
Pro tools 12 extremely slow (unusable), freezes on Windows 10 PC. Fresh new install. lorenzo.stavros Windows 8 10-18-2019 07:43 AM
New to PT, installed 12... so slow, it is unusable... josephhand Pro Tools 12 16 04-30-2016 04:07 PM
Software Bug Renders Pro Tools SE Unusable; Avid Support Unresponsive Starwind Amada Pro Tools SE and Essential (Win) 7 06-14-2013 11:00 AM
Digibase Error renders unusable bootc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-07-2008 12:55 AM
