I just started using PT11 and noticed that the MasterMeter plug completely uses up all of my cpu power and PT doesn't let me play anything at all. Even if the MasterMeter is the only plug on the tracks. If anyone can help me out with this please let me know. Thank you for your time.
K. |
![]() Quote:
That sure don't seem right! have to see if anyone else can verify this. Thanks for reporting it. Chris
Yup. Same thing was happening to me. One core would go through the roof.
stereo track
75% to 100% on CPU Total core 4 hovering between 45% 65% The same rolling or not rolling... stereo master fader track 15% to 17% on CPU total all others less than 11% The same rolling or not rolling
PT 12, Gigabyte GA-X79-UD3 ATX LGA2011 MB,Intel Core i7-3930 3.2GHz 6-Core Processor,Asus NVIDIA GeForce GT 640 2GB GDDR3 PCI-e Video Card, Patriot Viper 3 Low Profile Blue 32GB (4x8GB),Cooler Master Hyper 212 Evo CPU Cooler, Rosewill Stallion Series RD700 700W Power Supply,Western Digital Caviar Black Internal system/session/samples,Windows 7 Professional 64-bit,Mbox2 |
A friend if mine showed me it at first. Then I tried it on my PT11. It doesn't really bother me all that much while I am mixing because I don't use it then, but I use it while mastering. But I've only heard of one other verification of it happening on another system.
I pointed this out the day Pro Tools 11.1.0 came out and I was pretty ignored... http://duc.avid.com/showthread.php?t=348698
Producer/Engineer/Musician RIAA Platinum Sales Award: Lisa Stansfield "Affection" Main: Model: Dell 5750 Precision Workstation OS: Windows 11 Pro 64bit CPU:*Intel Core Processor i7-10750H (6 Core, 12MB Cache, 2.60 GHz to 5.00 GHz, Memory:64GB, 2X32GB,DDR4 2933Mhz Non-ECC OS M.2 512GB PCIe NVMe, Record Intel 1TB SSD, 2T SSD, 1TB SSD Focusrite Scarlett 18i20 3rd Gen AVID Pro Tools 2023.12 JBL LSR4328P 8" JBL LSR310S 10 inch Powered Studio Subwoofer* Yamaha HS50M Studio Monitors Alesis Elevate 3 Studio Monitors M-Audio Axiom 61 Midi Controller |
I tried putting the meter on a mono audio track, a stereo aux track and a stereo master (I feel like I should have tried it on a stereo audio and mono aux/master) but it seems like the stereo MasterMeter has a big it it, but the mono meter works just fine. Oh and I am running PT 11.1.2. Hopefully Avid will find this and fix the bug.
![]() Quote:
I'm also getting the CPU spike, even in a session with a single track with a single instance of MasterMeter. Total hits 100%. One core bouncing between 50% and 60%, the others idle. Even in a session and a single track with a single multichannel instance of MasterMeter. Mono works fine. No option for multi-mono. Adding a dither before didn't work, neither did adding a dither after.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
No I didnt say I solved it I said I found the problem, The "Mastermeter"
Justus, the issue you brought forth in the thread was CPU spikes. You solved the issue of CPU spikes shortly after posting by removing Master Meter. Just sayin', that may be why your thread didn't receive replies.
Plugin issue with PT11 | ReachMusicProductions | Pro Tools 11 | 15 | 10-09-2013 08:52 AM |
M-Powered Maxes out CPU | Tech2512Wave | Pro Tools M-Powered (Win) | 3 | 12-14-2012 10:29 AM |
Eleven maxes out my CPU!!! | FSM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-13-2008 12:19 PM |
CPU maxes out when a session is idle | Williard | Pro Tools M-Powered (Win) | 6 | 02-16-2006 11:47 AM |
CPU maxes out with only a few virtual synths OS X | soundforgames | Pro Tools TDM Systems (Mac) | 2 | 11-14-2003 11:30 AM |
