Old 07-17-2024, 07:37 AM
ubxf ubxf is offline
Default Re: Replacing Avid Xmon with Ginger Audio Sphere
Ok thank you, will do
Old 07-22-2024, 03:55 PM
creativecontrol's Avatar
creativecontrol creativecontrol is online now
You can also get to Diagnostics mode where you can test switches and displays on the module by holding down Select and Swap on the Attention strip for several seconds. You will see AVID logos - then follow the prompts to perform the tests.
best,
Jeff
Originally Posted by ubxf View Post
Thank you, do I need to do anything to disable Xmon in Eucon or can Sphere and Xmon co exist (even if Xmon is no longer in use). Also a side issue I just noticed that my Automation module on the S6 went dark. The transport keys are still working but the screen and Jog wheel are dark.
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-23-2024, 06:47 PM
Thank you for the suggestions. I did the reboot and the diagnostics. Reboot didn't change anything. Diagnostic looks like everything is working except the top 2 screens.
Old 07-24-2024, 06:33 AM
The top 2 screens that are not working are part of the master module not automation. Is there a way to do diagnostic on the master module
Old 07-24-2024, 12:24 PM
Another issue I'm having is with the com mic in the S6 . Currently it is wired directly into the TB/Util db25 in the back of the Xmon . I'm going to get that line into a preamp the question is , does that mic need any kind of power or is it provided by the S6 ?
FS: Avid D-Command with Xmon Mukan Buy & Sell 1 12-07-2019 03:23 AM
RIP Ginger Baker musicman691 General Discussion 2 10-16-2019 10:08 PM
Replacing a fader on Avid C24 (not Control 24) smetaxas ICON & C|24 13 10-13-2018 08:13 AM
avid xmon filip_a Buy & Sell 2 12-12-2016 02:04 AM
Avid Xmon zmagosmon Buy & Sell 5 12-07-2016 05:31 AM
