I could have sworn I've seen this asked before but I can't find a thread on this anywhere. I'm thinking about converting my older system into an external effects system but was hoping I could get a little help in this direction.
I know that signal flow states that no effects are applied pre-mixer, so we are able to hear effects when tracking but they aren't actually being applied because multitrack comes first. That said, if I have an audio track that isn't armed and the I/O is set for the input and output of my audio interface, would that, in essence, allow the signal to be passed from input > inserts > output? Honestly, I have Ultimate but there are just some TDM plugins that I really liked and would rather not pay the extra money for native. *cough*TC Electronics*cough..lol. Thanks in advance |
You can hear processing even if you are not recording. Just press the green "I" button.
![]() Quote:
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
So you were not quite clear and you might give more detail on exactly what you are thinking of doing.
BUT If you have two complete systems each with their own interface Then I would probably run the TDM system (Line In and Line Out) to and from the Ultimate interface - as if it were simply an external Hardware FX unit. And set it up as an HW insert in the "Inserts" section of your Ultimate I/O and then you can just select it in the inserts section of any audio track in the Ultimate system,,,, or better yet maybe set it up as an HW insert on an Aux track on the Ultimate system,, and then just send to it from any Ultimate audio track.
System : Studio - Avid Carbon interface , PT Studio 2024.10.2 Mid 2020 (intel) iMac 27" OS Sequoia 15.4 Mobile - 2021 14 " MBP M1 Pro PT Studio 2024.10 --Sequoia 15.4.1 Enjoy the Journey.... Kev... |
![]() Quote:
If you really want to do this I would try to do what Kev suggests with hardware inserts.
Is this for tracking or mixing? Do you have enough physical I/O to do all the hardware inserts you want to use here? If for tracking/monitoring are you and the talent going to be OK with the latency here? Even if mixing you may need to be careful with H/W insert latency, of course it depends on what you are doing, with what plugins (and their latency etc.), all the conversion latencies and the H/W buffer latency on the native DAW side. No idea what native setup you have but start by checking the null H/W insert case works with perfect delay compensation (using a straight through H/W insert cable). These things often end up being much more of a PITA than just running plugins in the host. |
![]() Quote:
![]() Quote:
The detail I was referring to was things like the number of physical I/O 's available to you And for example What is the make/model I/O of the interface for the TDM system ? What is the make model I/O of the interface for the Ultimate system ? This will tell us as (Darryl mentioned) if you have sufficient physical I/O especially on your Ultimate system interface. The TDM system will only be using 2 channels in and two out (assuming you want to be able to have the option of stereo effects) .. But for the Ultimate system you are going need 4 channels because you if you are using Outs 1-2 for your main monitors, then you are going to want to run the TDM in and out of physical 3-4 on the Ultimate interface Also (as Darryl mentioned ) be aware that (unless you have compatible digital I/O on both interfaces ) But if you have to use analog I/O then using the TDM plugins as an FX unit will add 3 additional conversions DA out of Ultimate --- AD into TDM ---DA out of TDM and --- AD back into Ultimate As far as routing inside TDM I would just set up an Aux track and just select the line in channels from the Ultimate into the TDM as the TDM Aux track inputs and then select the TDM output channels going out to the Ultimate as the TDM Aux track outputs. Then as I mentioned just use the TDM as a HW insert inside Ultimate and have the physical inputs and outputs from the TDM go to the physical Ins and Outs of say 3-4 on the Ultimate interface and then on the specific channel inside Ultimate select from the channel Inserts section the I/O drop down, and then select 3-4
System : Studio - Avid Carbon interface , PT Studio 2024.10.2 Mid 2020 (intel) iMac 27" OS Sequoia 15.4 Mobile - 2021 14 " MBP M1 Pro PT Studio 2024.10 --Sequoia 15.4.1 Enjoy the Journey.... Kev... Last edited by K Roche; 07-01-2024 at 11:26 AM. |
![]() Quote:
TDM Box - HD3 > 192i/o Digital Ultimate - HDX1 (on the way) > Antelope Audio Orion Studio HD Planned on using ADAT to minimize latency as much as possible. I really appreciate everyones input! |
Yes, that SHOULD work. Assuming a 44.1 or 48K session and a single set of ADAT(FROM the main rig TO the secondary rig, FROM the secondary rig back TO the main rig). Setting Clocking correctly would give you 8 sends and 8 returns. If you only use the secondary system from reverb and delay, any roundtrip latency will probably not be an issue(as long as these effect plugins are running 100% wet). Then you have the option of setting up hardware inserts, OR simply send out(to FX) and return as if you were using a few outboard effect units. I did this way back when with an old 001 system tied to an 003 system.
HP Z4 workstation, Mbox Studio https://www.facebook.com/search/top/...0sound%20works The better I drink, the more I mix ![]() BTW, my name is Dave, but most people call me.........................Dave |
Buying an older version of "Structure" license or software | Healtone | Licensing & Accounts | 1 | 06-28-2016 08:41 AM |
"Created with an older version of Pro Tools" | j4callen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-13-2015 08:37 AM |
Cannot open session in Mpowered7.3 (created in 7.3 but gives "older version" error) | Krizaps | Pro Tools M-Powered (Mac) | 3 | 02-18-2011 12:31 AM |
"Older Version of Pro Tools" lie! | BoFromUnrivaled | Pro Tools TDM Systems (Mac) | 6 | 05-19-2010 04:10 PM |
Can't open "session created on older version" - but it wasn't! | BookSix | Pro Tools TDM Systems (Mac) | 9 | 02-04-2009 07:38 AM |
