Avid MBOX Control Software Presets Don’t Stick on MBOX 🤷🏻*♂️
So, I created 4 “custom” Presets in my Avid MBOX Control Software. Then I selected them for the 4 physical colored buttons as custom actions. The 4 Presets save just fine in the software, but when my Presets are assigned to the buttons, they show up as selected on the menu, however when I press any of the colored button on the physical MBOX the Preset will change as expected, but then all of the button assignments go back to default assignments in MBOX Control software. Not sure why this is happening. Any guesses?
Tony Computer: Dell Inspiron 3020 OS: Windows 11 Home 64-bit Audio Interface: Avid MBOX Studio DAW: Avid Pro Tools 2023 Electronic Acoustic Drum Module: Yamaha EAD10 Mics: Shure SM58, Audio-Technica AT2020 Monitors: Tannoy Reveal 501a IEM: Xvive U4T9 Wireless IEM System Mixing Headphones: Beyerdynamic DT880 Pro Drums: 7 Piece Tama Superstar Classic Kit Cymbals: Sabian HHX Complex Drums: 4 Piece Tama Club-Jam Suitcase Kit Cymbals: Sabian Pro Last edited by MightyT; 12-18-2023 at 08:47 AM. |
Re: MBOX Control Presets Don’t Stick on MBOX
I'll have to try this, but how are you assigning a specific preset to one of the buttons? I thought the Presets function just displayed the Presets dialog.
So you appear to know how to create custom presets. Well I found that if you go to program the colored buttons from the top menu in MBOX Control it gives you a list of options to select for Press or Press and Hold. Well I found that after creating Presets it adds them to the bottom of the button lists as User Defined, thus my goal was to be able to easily switch Presets by just pressing the colored button on the MBOX. Like mentioned creating Presets works great and when you assign them to a button they show up in the top menu, but once you use one by pressing a button it will take you to that Preset, but resets all the buttons back to factory default. Got me!
Tony Computer: Dell Inspiron 3020 OS: Windows 11 Home 64-bit Audio Interface: Avid MBOX Studio DAW: Avid Pro Tools 2023 Electronic Acoustic Drum Module: Yamaha EAD10 Mics: Shure SM58, Audio-Technica AT2020 Monitors: Tannoy Reveal 501a IEM: Xvive U4T9 Wireless IEM System Mixing Headphones: Beyerdynamic DT880 Pro Drums: 7 Piece Tama Superstar Classic Kit Cymbals: Sabian HHX Complex Drums: 4 Piece Tama Club-Jam Suitcase Kit Cymbals: Sabian Pro |
Any thoughts? 😊
Guess there’s no one else with this problem. 🫤
Sorry for the delay in getting back to you. My MBox / MBox Control acts the same way, which I would think is a bug.
Hi MightyT - I coordinated your issue with our tech support team and they will check if this is a confirmed bug.
Regards, Charles ________________ To create an Avid Support Case, you may go to https://avidtech.my.site.com/avidsup...t-support-page |
Re: Avid MBOX Control Software Presets Don’t Stick on MBOX 🤷🏻*♂️
Thank you! I opened a case also, but 10 days and no real response. 😞
That’s not what I’m saying. I’ve 4 custom different presets and saved them as favorites. I the assigned each one to the 4 physical buttons on the MBOX as actions, thus when I press each button my preset would change in MBOX Control. I was able to set all of them up and could see them assigned in the top menu, but when I pressed any of the buttons the settings reverted back to default. Not sure why?
MBox Control vs. Pro Tools | MightyT | Getting Started | 4 | 08-27-2023 02:46 PM |
Control the Mbox control mixer with the ipad or control surface? | danielcordova | MBOX Studio | 1 | 02-24-2023 02:19 AM |
MBox Pro 3 not being seen by MBox Pro Control Panel | Dallas Taylor | macOS | 6 | 09-12-2013 12:17 PM |
MBox 2 Pro Control Panel | ThunderKyss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-08-2009 10:17 AM |
Mackie control and Mbox | Jburn34 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-10-2003 01:43 AM |
