Old 01-11-2014, 05:55 AM
Nate19 Nate19 is offline
Default OSX 10.8.5 & MBox Pro 2 were working but stopped (PT 11)
My MBox Pro 2 and my OSX 10.8.5 are no longer communicating. The system was working without incident for months and fell apart yesterday when I opened a session. I received a notice indicating an issue with the internal clock, another indicated two devices cannot share 48 kHz. I have tried everything, and am completely stumped.
Current Symptoms:
1. Mbox Pro 2 has a solid yellow light
2. Sound comes out of MBox headphones and Mac Mini speakers simultaneously.
3. Mics pick up sound when a track is record enabled but they also pick up sound with the track is not record enabled.
4. In addition to other commonly discussed issues.. for example, when I open a session I get the message "Some paths were made inactive because they could not be assigned to existing path definitions"
Hardware:
PT 11
OSX 10.8.5
MBox Pro 2
Actions Taken:
1. I've downloaded all the drivers for the MBox Pro 2
2. I've connected an MBox Mini 3, and everything worked fine
3. Rummaged through Hardware, Playback Engine, I/O Settings, etc. no luck
Exorcism advice?… How do I get an MBox to work with my Mac again? Thank you
Old 01-14-2014, 09:11 AM
weezamiah weezamiah is offline
Default Re: OSX 10.8.5 & MBox Pro 2 were working but stopped (PT 11)
You can try deleting the input in the i/o and reseting the defaults. I have the same setup for mobile recordings. Make sure in the hardware profile its set to mbox. sometimes it reverts back to the computers internal setting.
MBox 3 Pro stopped working johnwoog FireWire & USB Audio Interfaces (Win) 4 08-14-2013 06:16 PM
Mbox 2 stopped working. boohowdy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-26-2010 01:28 PM
Mbox 2 pro stopped working nolodevice 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-26-2008 08:06 AM
MBox 2 just stopped working Mixtrix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-21-2007 07:53 PM
MBox stopped working p_frog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-27-2004 09:39 PM
