Old 01-29-2013, 03:48 PM
Kemo3ce Kemo3ce is offline
Default Problem with sampling rate!!
ok so ive been recording in 88.2 for about a week now and when i first got pro tools 10 i tried using it in 192 and it worked perfectly so now i want to go back to that session but for some reason when i do the pro fire 2626 changes back to 88.2 and the session closes before i could open it.. could this be a setting in the pro tools software? has anyone had issues like this? can anyone help?
Old 01-29-2013, 05:38 PM
dr_daw's Avatar
dr_daw dr_daw is offline
Default Re: Problem with sampling rate!!
Did you try manually changing the Pro fire back to 88.2 before opening PT? then open the session?
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 02-01-2013, 10:19 AM
yes i actually did, i just went ahead and uninstalled the drivers and everything and then installed again.. it seems to be working fine for now.. hopefully that problem does not return
Old 02-02-2013, 09:20 PM
headstack headstack is offline
I am a bit confused here!
Were you trying to open a 192 session and gerting bumped to 88.2 as the session crashed?
Old 02-03-2013, 01:40 AM
Bill Denton Bill Denton is offline
I'd be curious as to why you're using 88.2 or 192 in the first place...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Anybody know what the max sampling rate of PT 8.0 LE is? Fabb2004 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-09-2012 10:58 PM
Sampling Rate Problem Please Help D.O.T General Discussion 0 07-13-2008 06:33 AM
16k sampling rate? guy.fi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-31-2007 03:03 AM
Sampling rate problem IPerez27 Post - Surround - Video 4 08-24-2004 08:38 PM
mbox sampling rate madincraft 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-05-2003 11:16 PM
