Old 05-18-2010, 02:23 PM
BoFromUnrivaled BoFromUnrivaled is offline
Default "Older Version of Pro Tools" lie!
I'm trying to pull up a mix I did a while back, and it gives me "cannot open session because it was made on an older version of pro tools". I assure you it was done on my 003 rig v8.0 (PC), the same rig I've used for a year now. I'm now running HD 8.0.3 (mac) and was hoping against hope that it would pull up, but no go. I reeeeeealy don't want to mix it again, any suggestions?
Old 05-18-2010, 02:36 PM
browniespeaks browniespeaks is offline
Default Re: "Older Version of Pro Tools" lie!
Check that the file extension has not changed. File> import session data is the prefered method of importing a session.
Clifford Brown III
Brown Audio Solutions & Services
www.brownaudio.com
Old 05-18-2010, 10:57 PM
TommyT TommyT is offline
Unhappy Re: "Older Version of Pro Tools" lie!
ooo I've seen that one a few times... The session is corrupt & you many not even be able to import tracks from that session....
Old 05-18-2010, 11:08 PM
worst case is you have to import the actual source material as audio and rebuild the tracks. If your going to remix it anyway this is not such a blow.
Clifford Brown III
www.brownaudio.com
Old 05-19-2010, 11:25 AM
PaulV's Avatar
PaulV PaulV is offline
Yes, that error message is totally misleading. What it most likely means, unfortunately, is that the session file is corrupted; you may want to refer to backups if you have them.
Would you mind sending me the corrupt session file at pt_transfer at digidesign dot com? I would like to see what's happened, and I can see if there's anything available to recover.
Cheers,
Paul Vercellotti
Avid Engineering
Old 05-19-2010, 01:24 PM
Dism Dism is offline
I concur... why does that error message even exist, considering you CAN open sessions made in older versions?
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 05-19-2010, 04:10 PM
DigiTechSupt's Avatar
The error is misleading, definitely. It's usually caused by corruption of the session - and the header that indicates which version of Pro Tools created the file.
If I'm not mistaken, we've implemented a different check scheme that should post a more appropriate error and will be included in future update to Pro Tools.
Avid Audio Tech Support
Support FAQ
"Created with an older version of Pro Tools" j4callen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-13-2015 08:37 AM
Cannot open session in Mpowered7.3 (created in 7.3 but gives "older version" error) Krizaps Pro Tools M-Powered (Mac) 3 02-18-2011 12:31 AM
Gibson Firebird X Guitar - "Overpowers older Pro Tools Set Ups" DrFord General Discussion 2 11-11-2010 03:51 PM
Can't open "session created on older version" - but it wasn't! BookSix Pro Tools TDM Systems (Mac) 9 02-04-2009 07:38 AM
do i have to buy "european" version of digi002, or use "american" with power adaptor? stoka General Discussion 3 10-04-2002 05:28 AM
