Old 08-17-2002, 07:50 PM
Centurion Centurion is offline
Default HD IO Options
192 vs 96. Reality please.
I mean, if I have a U87 going into a Manley VoxBox and then into a 96 versus a 192, will that be where it matters? Can I use the 96 for synths/drum machines and use a 192 for the vocals?
And although I am sure that this has been discussed before, who can actually hear the difference between a 192 and a 96 and please explain what you hear. And since the 96 is supposed to be so much better then the 888/24 then what does the MIX system sound like? Nothing great? Someone please put this in perspective as this delta is a large wad of cash.
Thanks to the experts.
Old 08-17-2002, 09:18 PM
shadowbox shadowbox is offline
Default Re: HD IO Options
I'll tell you what I know. I have the 192 and even at 48kHz/24-bit I would say it sounds as good as my Apogee AD-8000. Others would disagree. I haven't heard the 96 but would imagine that for synths and what not, it would be ok. Much better than a 1622 which a lot of people used for synths in a Mix system. The S/N ratio of most synths is such that the improved A-D converison doesn't really matter.
The really cool thing about the 192 is that it's a very versatile box. It's great having both the +4 inputs and the -10 inputs, along with the extra ADAT/TDIF/AES (with on the fly sample rate conversion). Depending on your set up you can almost use it as a patchbay. I have almost everything going directly through the 192 then depending on what input I need to use I can change it in the software. The 96 does this as well, but the 192 as a lot more input options.
Old 08-18-2002, 07:04 PM
ctmartin ctmartin is offline
I absolutely agree w/ Chris above...
Others have pointed-out that the components in the 192 are superior to the 96 -- converters, clock -- plus you get sample-rate conversion on in-coming digital signals, "soft-limiting", and as stated, lots of i/o options. I'm getting what I NEVER could have gotten from Mix / 888-24's... it's now MUCH easier to mix "inside the box" with these things, and the low-end is now a reality thanks to 192's. And this is just running at 44.1 & 48!!
-C
Old 08-18-2002, 08:28 PM
OK, thanks for the info, but that does not really answer my question.
If the 192 is so superior then where would one use the 96? I will be tracking mostly electronic music with lots of synths and drum samples, but also need to have the killer vox there and have spent big dollars on a U87 and a Manley tube pre. I ordered (2) 96's to get 16 analog IO, so should I now get a 192 for vocals and the Kurzweil grand piano sound? Just how and what is the realistic, audible difference? Or should I just forget the 96's and do only 192?
Old 08-19-2002, 01:29 PM
Mike Brosco Mike Brosco is offline
I went with the 192 and the A/D expansion I/O card. This gives me 16 analog inputs that sound unbelievable. You should check the prices of the 192 with expansion card vs. two 96 units. I haven’t heard the 96 but I can tell you the 192 sounds beautiful.
Old 08-19-2002, 02:33 PM
Lee Blaske Lee Blaske is offline
Search back through the archives. There was a lot written on this subject back when HD was first released. Essentially, the 192 and 96 are worlds apart in terms of design, components, construction and hence, sonics.
Lee Blaske
Old 08-19-2002, 02:55 PM
Yes, you are right about (2) 96's versus (1) 192 and the A/D extension. That is exactly what I just did. So now I will be getting a 192 with the A/D extension. No worries now, this is as good as they have to offer...
Now the only question is did I do the right thing going with the Manley VoxBox versus the GT Vipre.
Old 08-19-2002, 02:58 PM
nukmusic nukmusic is offline
Centurion, I asked this question a while ago planning to upgrade from Digi001....Like you, most if my music is done on keyboards and drum machines. One of the Sweetwater techs answered my question from a test he did. He said that the 192 sounds better than the 96, and the 96 sounds better than the 888/24. But reaaly didn't say by how much.
Docta'J
www.nukmusic.com
Docta'J
Download free music at
http://www.nukmusic.com
nEVER uNDERESTIMATE kNOWLEDGE
Old 08-19-2002, 03:01 PM
Also some said that 192 sounds as good as or if not better than the AD8000. Then I asked about just adding an AD8000 to Digi-001.......and a whole new debate started....lol [img]images/icons/smile.gif[/img]
Docta'J
where is my mp3 options nossnevs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-23-2007 04:47 PM
7.0 plus options skwad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-13-2005 04:26 PM
Options for G3 macD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-24-2005 08:54 AM
mix to pic options with LE/002 DARCsound Post - Surround - Video 2 06-30-2004 08:54 AM
HELP WITH MIX OPTIONS Pro Tools TDM Systems (Mac) 0 01-31-2000 10:52 PM
