Old 05-05-2008, 03:28 PM
Steve7 Steve7 is offline
Default How to remove space from the front of a song?
I have a session that has too much empty space at the beginning of it, and I'm trying to figure out how to delete some of it. It has 30 seconds before the first instrument starts and I want to make it about 5 seconds. I know that I could drag all of my wavs to the front of the timeline, but I'm wondering if there is another way to just delete time on the front of the song?
Thanks for the help.
Old 05-05-2008, 03:34 PM
Craig F Craig F is offline
Default Re: How to remove space from the front of a song?
change the session start time
Thank you,
Craig
Old 05-05-2008, 03:40 PM
citi citi is offline
or..highlight the empty space from the time line (which will select all tracks) in shuffle mode and press delete.
CiTi
http://www.checkonet2ent.com
Old 05-05-2008, 04:30 PM
Highlighting the empty space and then hitting deleting it in shuffle mode doesn't work.
I don't want to just change the starting time, I want it removed all together. I can't just drag the wavs because the playlists don't seem to drag with the active tracks.
Any ideas?
Old 05-05-2008, 04:59 PM
Alan Brownstein Alan Brownstein is offline
To my knowledge you can't really remove empty space in the way you're describing. Your best bet is to select all regions on all tracks in the session (i.e. highlight the "All" group), then use cut and paste to move them all en masse to the start of the session, or wherever desired. The automation underneath the audio regions should be preserved when you cut/paste them.
Old 05-05-2008, 05:06 PM
Phil Ogden Phil Ogden is offline
Remember to include the tempo and marker rules when copying if there are tempo changes/markers that you want to keep locked to the underlying audio.
http://www.myspace.com/philogg
Old 05-05-2008, 07:15 PM
How do I highlight the "ALL" group?
Old 05-05-2008, 07:16 PM
are you sure? because I just tried it and it worked perfectly.
CiTi
Old 05-05-2008, 07:18 PM
Nevermind, I figured out the right way to do it.
In case any of you guys need to do it, do this:
Event > Time > Cut Time
Has no one here ever used this method?
Old 05-06-2008, 02:05 PM
Ok, the "cut time" doesn't move the unactive playlists with it. So I need another method.
Can you walk me through the method of selecting "all"?
Thanks alot.
How to remove the drums and guitar from a song ? KGB2011 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 03-14-2010 04:45 AM
How can i Remove Vocals from a Song? m4ca Tips & Tricks 1 04-14-2007 08:02 AM
Need to Remove the Lead Vocal from a Song Mike Harrison 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-30-2007 11:26 AM
If I remove Pro Tools will I loose my current song mezmoriz2001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-14-2006 07:31 AM
what's the best way to remove vocals from an existing song? heartparts 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-21-2003 12:45 AM
