I'm a long time Akai user, who's now kind of trying to move over to Soft SampleCell (keeping my S3000 for a while longer though, just in case).
When doing drums, I prefer to map several sounds (using my master keyboard) to one MIDI channel, then testing sounds and recording the MIDI. When things start to sound right, I lift the used sounds out of the multi-set and give them a program and an output of their own. This doesn't work well in Soft SampleCell First of all, is there a way to expand the number of MIDI channels for Soft SampleCell. I mean with 32 simultaneous outputs, how can 16 MIDI channels be enough? When doing multi-layering that needs elaborate mixing, sure ... but still, it'd be nice to have 32 MIDI channels to go with the 32 outputs, no? Is there a way to map samples to the keyboard using my MIDI master keyboard? This is so easy on Akai, and maybe I've just missed something, but if it's not possible ... then that sucks; big time. And does all keys have to have a sample? That's ridiculous. I want to be able to map a sample to one single key, and have no samples on the rest of the keys. Is that possible with Soft SampleCell? Is there a way to assign different outputs to different samples in the same multi-set (same midi channels)? It doesn't appear so. If I have a multi-set, and want to output one of the samples on a different output, I have to assign it to a different MIDI channel? Is that correct? Cause if I don't, that single sample will be mapped all over the multi-set's channel? Problem "solved" by creating different single sample "sets" with different midi channels and outputs - stopped only by the available 16 midi channels (and the 32 outputs, but that will be enough for me I think). Or am I missing some features, or better workarounds? |
![]() quote: -SSC is limited to 16 MIDI channels -A stereo sample takes up two voices...therefore 32 voices are needed if all 16 MIDI channels are triggering instruments containing stereo samples quote: -If I understand your question properly, you can do this by Control+clicking the Low or High Note fields in an instrument and then "play" the range you want. quote: -You are correct, there is no "space" between samples...they're always adjacent. You can work around this by creating a "null" sample with no audio and only a few milliseconds in length. Load the "null" sample where you want silence. We are aware of this problem (this is how SampleCell has worked since the start 10 years ago) and look to address it in a future release. -You can map a sample to a single key when using a multi-sample instrument in which contains more than one sample. -You can also limit the range of notes the instrument responds to by adjusting the Lo and High MIDI notes. quote: -No, not right now. You can have multiple copies of the same instrument assigned to the same MIDI channel, but different outputs though. quote: -Yes...kind of. It's not really tied to the MIDI channel, however, you are not able to have more than a stereo out per instrument. -As an alternative, you can make a copy of the instrument and restrict the note range that the instrument responds to. Brent [ July 20, 2001: Message edited by: DigiTechSupt ] |
Soft Samplecell | hornflakes | Digidesign Hardware & Software | 0 | 04-29-2002 03:56 PM |
Soft SampleCell not compatible with SampleCell 2 | P BUCKLE | Digidesign Hardware & Software | 13 | 06-08-2001 11:01 AM |
New to Soft Samplecell Help!!! | Kenny Gioia | Digidesign Hardware & Software | 1 | 06-07-2001 05:31 AM |
Soft SampleCell not compatible with SampleCell 2 | P BUCKLE | Pro Tools TDM Systems (Mac) | 11 | 06-06-2001 10:24 AM |
Samplecell newbie questions | glava | Digidesign Hardware & Software | 1 | 12-08-2000 08:17 AM |
