error msg that I have never seen before
Hi!
Everytime I play a track - something on it i receive this message (this time EXDrummer on track nro2) - and everything stopes - ------ "Audio processing deadline was not met. This has been fornalllinng plugin Plugin: EZDrummmer 3 (0.0.0.0..311) Track: Drums Insert: B Try inate the plugin inecreatink "HW or Performance At Low Size" in The Payback Engine Dialog AAA-9113 ------ I am PT 2022.4 and I run a PC 4,6G, 16 RAM, 4 cores. DO YOUO HAVE HAD PROBLEMS LIKE THIS? Every help is welcomed, Sorry, English in not my mother tongue.
Win11 Pro Intel i7-12700K @3,6GHz, RAM 32GB UAD Apollo and pre-amps, Pro Tools 2023 lots of plugins Last edited by senghor; 06-27-2022 at 11:59 AM. |
Re: error msg that I have never seen before
No answer yet, but more questions:
1-EZdrummer 3? Have you opened a support ticket with Toontrack? 2-Did it ever work before?(new problem or its never worked right) 3-Your post says 4.6GHz but your signature says 3.5GHz. If you are over-clocking, test at standard clock speed(maybe the over-clock is making the system unstable) 4-What interface? 5-What buffer size? 6-VI plugins USUALLY do best in Insert Slot A(so try this)
These plugin error messages are new in more recent versions of Pro Tools.
Either increase the buffer or reduce the number of plugins, especially the CPU hungry ones. Keep an eye on your system usage meters in Pro Tools. What buffer size are you using? Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2 https://www.waves.com/r/djgsi6 |
Yes, this error means that you are running out of processing power within Pro Tools, so playback stops, and you see the new error message.
EZ Drummer 3 is rather new, so did this just start happening when you upgraded to or started using EZ3? If so, it's probably because the new version uses more processing power and your system was right on the edge. If you have a lot of virtual instruments in your sessions, freeze some of the tracks to free up CPU. At this point, it's probably a good idea to orchestrate your drum parts first, then freeze them so you can work on other tracks without the error. |
Given how many people have issues with Track Freeze, I recommend using Track Commit instead. I prefer to right-click on the VI plugin and choose "Commit up to this Plugin", but only make the original track inactive, until I am positive I no longer need to make any changes(its easy to delete a "commit" track later on).
OMF error: OMFI_ERR: Bento container error;In omfsOpenFile. on open/import | marcnyc | Pro Tools 2020 | 8 | 05-21-2020 11:43 AM |
Transfer of Ownership Fail - Error: Error occurred while loading a Visualforce page | Chevron | Licensing & Accounts | 10 | 12-19-2019 12:35 PM |
Pro Tools 9 Playback Error Lead to DAE Error 743 Which Lead to A CPU Overload Error | EricMulhern | macOS | 1 | 11-20-2011 05:39 PM |
Error type 10,address error ,illegal error, buss error ,illegal instruction | KasticK | Pro Tools TDM Systems (Mac) | 3 | 05-14-2003 11:21 AM |
Buss error,Address error,ilegal instruction,error type 10 | KasticK | Pro Tools TDM Systems (Mac) | 1 | 02-08-2003 05:49 PM |
