Old 06-14-2022, 10:45 AM
senghor senghor is offline
Default When I open PT a problem surface
I am on Win10 and I am running PT 2022.4. My interface is Apollo Solo.
A new problem has disabling me t0 record or mix. When open PT everything runs ok. But when I am trying to a apen a session PT says "The current playback engine does not support at the rate of 48 kHz".
Has anyone had this problem? And how resolving it.
Thanks.
Win11 Pro
Intel i7-12700K @3,6GHz, RAM 32GB
UAD Apollo and pre-amps, Pro Tools 2023
lots of plugins
Old 06-14-2022, 10:58 AM
sw rec sw rec is offline
Default Re: When I open PT a problem surface
Windows is likely using your Apollo as the default sound device. Go to Control Panel-sounds and designate your onboard sound device as the default for Windows sounds so PRO TOOLS can have exclusive access to the interface.
Open PI preset from surface Gregor B. Avid S4/S6 19 04-25-2022 03:09 AM
Profile surface VGA problem yagga121 VENUE Live Sound Systems 8 08-23-2012 07:14 AM
PT 6.4 Control Surface Problem PatrickJ 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-20-2005 04:37 PM
Control Surface Problem artvolk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-14-2005 08:21 PM
CS-32 control surface problem avanti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-20-2005 10:48 AM
