How does one create a new session, or set an existing PT session so that the graphics (bar ruler) and click reflect true 6/8?
Setting the meter to 6/8 does not result in bars showing six beats per bar. Instead, each bar contains three beats; What command or procedure produces 6/8 meter represented by bars containing 6 beats? Also, no matter whether the meter is 6/8 or 3/4, the PT generated click seems unable to accent the desired downbeat for 6/8, it always accentuates a 3/4 count; ONE 23, ONE 23.... Instead of; ONE 23456, ONE 23456.... When poking around in search of a solution, PT click glitched out on several combinations of note-values and it became unpredictably clipped or even intermittent. Seems broken. Either this all used to work better or I'm forgetting something after being in MIDI 40+ years... and PT for 25. Completed obligatory Google searches, seeking suggestions, education. 2020 M1 MINI Apollo Quad Interface Sonoma 14.7.2 PT 24.3.1.162 Last edited by Robruce; 01-25-2025 at 04:01 PM. |
For 6 Beats per Bar (ONE 23456), set Meter to 12/8
Check the current PT Reference Guide - page 1068
In actual practice, I've usually set the Meter to 6/8, made a click out of a percussion VI, committed a bar of it, and looped that throughout the timeline.
Kerry Smith http://apothekerry.com Pro Tools since '94. Mac Studio M1 Ultra : 128GB RAM : Sequoia 15.4 : Carbon : PT Ultimate 2025.6 : S1 : Metagrid Pro |
That did it. Brain got stuck thinking '6/8' when 6/4 (or 12/8) was the ticket. Click and measures behaving as needed now.
Thanks very much. Last edited by Robruce; 01-25-2025 at 01:05 PM. |
![]() Quote:
Thanks for the manual reference MK, will read up. embarrassing.... Yes 8th note grid resolution works ok Yes indeed looping a click is one good way to get what you need, and no doubt less annoying than a mechanical click. The problem was/is that 6/8 resolves to 3/4 or waltz time (duh me) with the click sounding ONE 23, ONE 23, and bars of three beats. Exactly what I didn't want. For some reason '6/8' got stuck in the old brain, when 6/4 or 12/8 is the 'right' meter. So unkJE's suggestion of 12/8 brought the bar length and click to where it needed to be. ONE 23456, ONE 23456. And so actually either 12/8 or 6/4 with the grid set to quarters or eighths does the trick for the bar and the click. Thanks much! Last edited by Robruce; 01-26-2025 at 07:44 AM. |
Mono channel meter level lower than Master’s meter level | Armando | Pro Tools TDM Systems (Mac) | 3 | 07-07-2019 04:51 PM |
why external vu meter/ plug-in vu meter differ? | sjtae | macOS | 8 | 06-06-2012 05:50 PM |
Inserts affecting send meter but not channel meter? | Kbrinson85 | Windows | 1 | 05-01-2012 07:00 AM |
PTHD8 cpu meter vs task manager cpu meter | MEAT | Pro Tools TDM Systems (Win) | 5 | 01-02-2009 05:17 AM |
pci meter | raywong | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-29-2001 09:07 PM |
