I was using the Import Audio function in PTHD 7.3.1 cs2 and for the first time, I noticed the search box at the top of the dialog box. I popped in the name of the track I was looking for, sorted the list by date, and viola! The search brought it up the track I was looking for in the file view and identified it as a WAV. Super handy.
However, I can't get the file to show up in the "convert" so I can finish the import. If I click on the file name, nothing happens. If I double click the file name, the import dialog disappears. What's going on? The search box is cool--but apparently not supported? Browsing to the file still works fine. |
Yes. Crazy isn´t it? Since this feature has shown up (around 6.x) it has never worked. Allthough there´s a search function in the window you can neither audition nor import the files you have found.
Also because Digi asks you to turn off spotlight the search doesn´t work anyway if you follow digi´s requirements fully. So the whole feature is pointless. Unfortunately, because the import-window is the only way to control the volume when auditioning a file. frank.
PTHDnPCIe 2025.6 (OSX15.5), Eucon 25.6, 8x8x8, MacPro 14,8, Decklink SDI 4k, SYNC HD, Nanosyncs HD, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
![]() Quote:
Martin
Mac Pro 2,4 GHz 12-Core Intel Xeon (Westmere) 32 GB RAM, OSX 10.10.5, HD I/O 16x16 analog, HD I/O 16x16 digital, 192, PT HDX2, PT HD 12.6.0 http://www.pelhamundhaas.de/index2.html http://www.pelhamundhaas.de/vita.html www.3-p.de www.imglashaus.de |
I cant preview audio in digibase or import audio dialog. | sammyfarr | Pro Tools TDM Systems (Mac) | 0 | 03-29-2007 01:16 AM |
Small "import audio" dialog bug? | thierryd | Pro Tools TDM Systems (Mac) | 0 | 12-10-2006 04:24 PM |
Import Audio dialog , Can't select or play audio | Irl Sanders | Pro Tools TDM Systems (Mac) | 11 | 10-04-2006 02:02 PM |
5.1.1 Import Audio Dialog - another change? | barden | Pro Tools TDM Systems (Mac) | 1 | 06-29-2001 02:35 PM |
Import Audio dialog PROBLEM | jimlongo | Pro Tools TDM Systems (Mac) | 1 | 03-12-2001 03:32 PM |
