Old 08-08-2006, 05:50 PM
grahamfx grahamfx is offline
Default Performing live with Pro Tools
Hi all,
Today's problem is about performing live with Pro Tools LE. I would like to play live guitar along to backing tracks, using Plug-ins as guitar effects with automation. But tracks have to be record-enabled to monitor input signals, and this disables automation reading. Is there a way to prevent automation from disabling itself when the track is record-enabled? If so, I could make plug-in changes that match the structure of the backing track.
To sum-up, does anyone manage to use Pro Tools as a live multi-effect with automation? (Wouldn't it be nice? )
Thanks in advance.
Old 08-09-2006, 12:15 AM
Bobbers Bobbers is offline
Default Re: Performing live with Pro Tools
Just a thought and dont know if it works, but
Create an audio track for recording and then an aux track for automation. Then set the
output of th audio track to the input of the aux track and then do all the automation on the
aux track. Wouldn't protools then record on the audio track and read all the automation on
the aux track and thereby effecting your audio signal ?
Dont know if above will work, just an idea.
best wishes
Old 08-09-2006, 05:21 AM
Works perfectly this way! T H A N K S
Old 08-09-2006, 11:25 PM
thesneakyjesus thesneakyjesus is offline
can't you also just put it in latch mode?
How can I monitor AmpliTube 3 in Pro Tools 10 while I’m performing or recording? S9uga macOS 6 04-13-2012 04:11 PM
Pro Tools performing better with MBox than Digi003... Chief Pronto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-08-2009 03:46 AM
Pro Tools LE performing horribly on a capable MacBook Priory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-04-2009 08:19 AM
Performing Live philadesigns Virtual Instruments 0 03-04-2009 03:18 PM
Ableton Live - performing/recording live w/HD3 Surth Pro Tools TDM Systems (Mac) 1 09-11-2006 04:50 AM
