  #31
Old 04-26-2023, 01:25 AM
zikayan zikayan is offline
Default Re: PT 2023.3 keylayout problem with AZERTY keyboard [PT-299479]
EDIT - sorry, despite of below text, the issue is not solved under Silicon mode
issue solved here in the local preset menu (on the right of presets numbers)
- if locked, unlock setting files
- save settings as (aka "my azerty") -> protools asks for a "Window Presets" folder, where is it ?
- lock setting files
Now Protools starts with the correct setting (works under Rosetta and Silicon modes) -> no, issue remains, protools starts with qwerty US shortcuts
  #32
Old 04-26-2023, 01:42 AM
Caramiafreddie Caramiafreddie is offline
Hello, I have the same issue since I installed Protools studio 2023.3.
I hope Avid will resolve this issue very soon because there are so much issues in this version.
Thanks
  #33
Old 05-03-2023, 02:43 AM
sibernard sibernard is offline
Same problem on Ultimate-Windows-Azerty... I hope the update won't be long... it's incredible to send an update that slowed down a whole community of users for months. The only solution is to uninstall and downgrade to PT 2022.
  #34
Old 05-03-2023, 04:19 AM
Ale Ale is offline
You just have to activate two keyboard layouts in mac and toggle between them. Then my keys work normal again
Ale
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+
  #35
Old 05-04-2023, 02:52 AM
THANKS This solution works on PC too... and is faster than going to PT prefs. But it is still not normal to have to do a manipulation after each restart of PT. While waiting for the next Update, we will get used to doing it like this...
  #36
Old 05-12-2023, 08:07 AM
soundsprout soundsprout is offline
Default Re: PT 2023.3 keylayout problem (QWERTY-AZERTY)
Originally Posted by Frank Kruse View Post
For what it's worth, it doesn't seem to affect German QWERTZ keyboards.
Well, it affects my swiss QWERTZ keyboard... exactly the same issue here!
  #37
Old 05-20-2023, 02:43 AM
Touf Touf is offline
Ale
Thank you for this workaround, you saved my day !
  #38
Old 05-29-2023, 11:54 PM
soundwizard_belgium soundwizard_belgium is offline
I hope they do a new version asap to solve this. Very annoying.
  #39
Old 06-08-2023, 01:06 PM
b_noise b_noise is offline
It works, finally everything went back
command + numeric keypad
and azerty keyboard shortcuts
great
thanx Avid
  #40
Old 06-15-2023, 05:27 AM
Kirito Kirito is offline
What do you mean by " everything went back " ?
Today I installed Pro tools 2023.6 and it's QWERTY shortcuts, I need to put back AZERTY.
edit : OK i find a way to put it back in AZERTy !
AZERTY keyboard... Nese 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-19-2007 12:35 AM
Key commands azerty keyboard [solved] Eli V/d Vondel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-09-2006 10:48 AM
keyboard AZERTY QWERTY blashol Pro Tools TDM Systems (Mac) 1 06-11-2005 11:50 AM
ProTools 6.7 AZERTY Keyboard Shortcuts Big Problem George Dyson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-08-2004 04:12 AM
Shortcuts changes on AZERTY keyboard... igloo701 Pro Tools TDM Systems (Mac) 7 11-23-2004 01:58 AM
