Old 09-26-2013, 03:25 PM
johanp johanp is offline
Default PT 11 recognize keyboard but not PT 10?
Hi
I own a korg microkey37. I've had problems with getting PT10 recognize it, sometimes it works and sometimes it does'nt. Now though when i got PT11 it works perfectly good.
The problem is that PT11 keeps crashing... so I need to go back to PT10 for now. How come it works in PT11 but not in PT10? I haven't done any changes.
Thanks
Johan
Old 09-26-2013, 04:33 PM
The golfer The golfer is offline
Default Re: PT 11 recognize keyboard but not PT 10?
I'm not sure if this will help, but I had a problem when using midi tracks in PT10. My controller wasn't the same as yours but it would not communicate with structure in PT10 neither. I lost tremendous amount of time trying to make it work on two different workstations.
I solve the issue by creating "instrument tracks" instead of plain "midi tracks".
Serge Hamel
Mixer / Sound Designer
http://www.netpostproduction.com
http://immersivesoundvr.com/
Old 09-26-2013, 05:43 PM
Originally Posted by johanp View Post
Hi
Thanks
Johan
Windows or Mac? The Korg is just a USB controller; if you're on a Windows machine USB ports can be set to power down (aka sleep mode) so make sure the USB ports aren't shutting down. Another possibility is your computer doesn't have enough power to power the keyboard through the USB port or the power supply in your computer is marginal.
Jack
QAPLA!
Old 09-27-2013, 03:28 AM
I'm using windows. But seems like it might have been fixed now. Reinstalled the drivers for the midi keyboard and used another usb port. Its allways something too easy...
Hopefully it will keep working! Thank you for the suggestions!
Johan
Re-recording mixer & Sound designer
Intel Core i7 3770K, 16mb RAM, AMD Radeon 7870
Windows 7
Mbox 3
Pro Tools 10.3.7
Pro Tools 11.0.2
Korg microkeys37
Old 09-27-2013, 04:21 AM
What drivers? The specs for your keyboard say no drivers are necessary. You say you used another USB port - Windows is funky with those ports, especially if you really need to use drivers with something. Connect a peripheral up to one USB port, install drivers if necessary, and if you move said peripheral to a different port it won't be recognized.
Jack
QAPLA!
Old 09-27-2013, 09:33 AM
Yeah thats the thing, they say there is no need for drivers but it appears there are drivers available anyways for the keyboard. And with that software i could uninstall a previous corrupted installation(in addition to the correct one), which i couldn't see otherwise, that probably have been causing trouble.
As you say, Windows is funky with USB ports and drivers.
Anyways, its still working. Thanks.
Johan
Windows 7
Mbox 3
Pro Tools 10.3.7
Pro Tools 11.0.2
Korg microkeys37
ProTools 8.0.3 doesn't recognize keyboard ancormier Pro Tools SE and Essential (Mac) 0 12-19-2012 07:10 PM
Pro Tools 9.0.2 Update Won't Recognize Oxygen 61 Keyboard Anymore StrokeMyAxe Windows 6 05-09-2011 02:29 PM
Pro tools 8 will not recognize M-Audio midi keyboard jonslaten 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-12-2010 10:11 PM
Pro tools doesn't recognize my keyboard... Zombie Crunch MIDI 5 05-08-2009 01:38 PM
How can I make Pro Tools LE recognize my midi keyboard? Antonio Tarantino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-26-2003 12:10 AM
