Output shuts down when I bring up an older Pro Tools session from 6.9
I'm simply trying to pull up an Pro Tools session from when I had Pro Tools 6.9. There's a little bit of "normal" hiss I hear in my speaksers. When it loads I can hear the speakers and the output shutting off. All of the file wav audio is there and it simply and it's playing but I can't hear it. I got my Focusrite 18i20 selected as my playback engine. I go into my I/O settings. I got in delete all of my paths in the input, output, bus and insert tabs. Use the default option and it still won't play. If I make a new session with the exact same set up for audio it will play. I could import the audio into that session but the files aren't consolidated and I'm still working with them at this point. I shouldn't have to do that. I don't know why it would turn the output off like that when it loads that old session. I Youtubed and googled and looked for 2 days now and can't find what might be causing that. Other more current sessions work and play just fine.
Re: Output shuts down when I bring up an older Pro Tools session from 6.9
Hi, welcome.
You have of course made shure the output settings of tracks and master are set correctly? What if you try to route a track to a aux? Does it register on the aux meter? Also look here, and go thru recommendations on optimizations, troubleshooting and providing system info: Help Us Help You
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
I do have all of the tracks and master set correctly. I ended trying something. I exported the tracks into a new session and selected them all. For some some that worked. Still wish I knew why opening that old session shut down the output audio path but I guess I found a work around.
Whenever you have I/O issues the first thing I would do is hitting default on every single tab on I/O setup. Then reroute and try again. If it still does not work, importing session data usually saves the day.
I’ve had the odd session or two where I had to delete all the paths before hitting the default button to clear up whatever issue I was trying to address.
Noob question: How do I bring up Mac Built-in Output in my session? | Rikki127 | macOS | 5 | 10-08-2020 11:36 AM |
Pro Tools session file converted itself to an older version | MetalGarret | Pro Tools 9 | 1 | 10-18-2014 02:04 PM |
Pro Tools 8 shuts down during session playback AHHHH! | ostrange | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-04-2010 03:18 AM |
Closing Session Shuts Down Pro Tools | ryanwilsonfive | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 10-18-2007 11:00 AM |
how to bring more pro tools sesions to one session | ak47 | Tips & Tricks | 1 | 09-02-2004 10:18 AM |
