Old 03-22-2018, 11:22 AM
RichrdC RichrdC is offline
Default PT 2018.1 crash & fix
Has anyone else noticed this situation? I open a session, and when I hit the play button, it's all crackly and low volume with lots of hesitations. So I go to the Playback Engine & change the value to anything other than what it's set to. Close the window, hit the play button, and all is well. I do have Elastic Audio enabled and seem to remember an issue with the playback engine.
Old 03-22-2018, 01:39 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Default Re: PT 2018.1 crash & fix
I have found this happens if you have interface or USB issues but it depends on your system, interface, etc.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 32 Gig Memory:Seagate 2 TB,1TB,4TB,500gb EVO OS Windows 7 Ultimate
PT 2019.6 Native through A&H Qu-32
Old 03-22-2018, 04:21 PM
john1192 john1192 is offline
happens from time to time .. and has been happening for quite awhile now .. not exactly sure when this started but Avid has not found a comprehensive solution yet ..
toggling Buffer usually fixes it for me ..
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD -OS 10.12.6 for PT 11.3.2 & 2019.6 last version
Logic Pro X latest version
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.14.6 - PT 2019.6 Ended here ..
RME BabyFace Pro
Upgrading from 2018.1 to 2018.3 with Application Manager lm183902 Pro Tools 2018 2 03-19-2018 05:41 PM
Reverting from 2018.3 to 2018.1 jamesleonard Pro Tools 2018 11 03-12-2018 06:21 AM
Xpand!2 2018 & Air Instruments 2018 lgreen100 Pro Tools 2018 16 02-15-2018 06:01 PM
Deleting multiple instances of multichannel instrument presets causes crash in 2018.1 noiseboyuk Pro Tools 2018 4 01-29-2018 07:43 AM
Installed 32track le version, won't run with Reaktor crash crash crash Christian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-02-2002 12:05 PM
