Old 02-24-2000, 11:44 AM
Jules Jules is offline
Default 001 / VHS movie w SMPTE timecode audio track / Universal Slave Driver...??? Sync OK?
Will this run ok? If not what box will make it run OK. Obviously the video tape must be the master.
TIA
Jules
Jules
London, UK
Come hang with us here!
www.gearslutz.com
Old 02-26-2000, 04:38 AM
Default Re: 001 / VHS movie w SMPTE timecode audio track / Universal Slave Driver...??? Sync OK?
hup!
Jules
London, UK
www.gearslutz.com
Old 02-26-2000, 07:36 AM
CCash CCash is offline
Hi Jules. Don't wanna talk about stuff I don't know, but I'm pretty certain you can't use a USD with the 001. All SMPTE must be converted to MTC.
I've dumped the audio off of a VHS tape into Pro Tools, then using an audio overdub feature on my camcorder, striped the audio of the VHS tape w/SMPTE via Opcode Studio 4, and had low-budget MTC "lock" (Studio 4 will read and convert SMPTE).
Seems the best lock for the 001 is a combination of MTC for trigger sync, and using MOTU's DP or the Aardsync for positional sync, but don't quote me...
Old 02-27-2000, 07:29 AM
Ah yes MTC Thanks!
any more tips graetly apreciated..
Jules
Jules
London, UK
www.gearslutz.com
Old 03-02-2000, 12:41 AM
Shreba Shreba is offline
A pretty cheap way to get your smpte converted to mtc is with a box from J.L Cooper called the DATASyncII, it sells for about $219
Old 03-02-2000, 04:12 PM
bcjucker bcjucker is offline
I'm interssed in the same question. I work at the moment with PT4.3.1. and the USD, but suffer about the only 2 outputs of the AMIII-Card. As long as I heard, the Digi001 only syncs to MTC. The USD itself also has a MIDI output. So the way of the signal will be SMPTE from Beta to the USD. This converts it to MTC. The MTC goes to the 001 and then Your in sync. But there is a more direct way from SMPTE to MTC. And a cheaper....
There are lots of SMPTE to MTC converters on the market. J.L. Cooper f.e. is not a bad idea, but there are even cheaper solutions working properly.
Smpte slave driver the_dr38 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-30-2010 11:44 AM
USD (Universal Smpte Driver) anyone using with OSX,.. 6.4.1? bullyboy Pro Tools TDM Systems (Mac) 1 05-25-2007 04:27 PM
Smpte Slave Driver pontuso Pro Tools TDM Systems (Mac) 7 02-20-2003 03:30 PM
SMPTE Slave Driver / PT 4.01 dodl Pro Tools TDM Systems (Mac) 2 02-15-2001 02:11 PM
Old Smpte Slave Driver musicfamily Pro Tools TDM Systems (Win) 1 08-15-2000 09:12 AM
