Old 02-05-2013, 05:29 AM
jon superdeath jon superdeath is offline
Default Trying for about 2 months (!) to get this running
I am at my wit's end. Pro Tools 10 is ruining my life. I have sought help on this forum and on others. I have received a number of very helpful suggestions, none of which has ultimately solved my problems. I am getting a variety of error messages, the most prominent of which being the "ASIO device properties changed" error. I have done every optimization recommended by the Avid knowledge base. I have also implemented every trouble-shooting suggestion on same. I am currently downloading the recently released 10.3.3 version of PT. A Sandra is posted below. I really just want to return the software to the vendor at this point, but I've been working on getting this program to work for a couple months (yes, really). I'm afraid that they won't accept a return, and I've just thrown a lot of money down the drain. Good Lord, somebody please help me!
Bah, I will post the Sandra a little later. It's taking forever, and I think I did something wrong anyway. Thoughts?
Old 02-05-2013, 06:27 AM
Default Re: Trying for about 2 months (!) to get this running
SiSoftware Sandra
ID
Host Name : JonSuperdeath
Workgroup : WORKGROUP
Computer
Model : ASUS N61Vg
Serial Number : 101728******
Chassis : ASUS Notebook
Mainboard : ASUS N61Vg
Serial Number : BSN1234567**********
BIOS : AMI (OEM) 207 08/31/2009
Total Memory : 4GB DDR3 SO-DIMM
Processors
Processor : Intel(R) Core(TM)2 Duo CPU P8700 @ 2.53GHz (2C 2.67GHz, 3MB L2)
Socket/Slot : FC µPGA (Socket P)
Chipset
Memory Controller : ASUS PM45 Mobile Controller Hub 4x 267MHz (1GHz), 2x 2GB DDR3 SO-DIMM 802MHz 128-bit
Memory Module(s)
Memory Module : Hynix (Hyundai) HYMP125S64CP8-S6 2GB DDR2 SO-DIMM PC2-6400U DDR2-800 (5-6-6-18 3-24-6-3)
Video System
Monitor/Panel : Samsung Generic PnP Monitor (1600x1200, 160AT06-A01
, 15.9")
Video Adapter : NVIDIA GeForce GT 220M (4CU 32SP SM4.0 1.35GHz, 1GB DDR2 1GHz 128-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : NVIDIA GeForce GT 220M (32SP 4C 1.35GHz, 1GB DDR2 1GHz 128-bit)
Compute Shader Processor : NVIDIA GeForce GT 220M (32SP 1.35GHz, 1GB DDR2 1GHz 128-bit)
CUDA GP Processor : NVIDIA GeForce GT 220M (32SP 4C 1.35GHz, 1GB DDR2 1GHz 128-bit)
Storage Devices
Seagate ST9320423AS (320.1GB, SATA300, 2.5", 7200rpm, 16MB Cache) : 298GB (C:)
TSSTcorp CDDVDW TS-L633C (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
Logical Storage Devices
System Reserved : 100MB (NTFS)
Hard Disk (C:) : 298GB (NTFS) @ Seagate ST9320423AS (320.1GB, SATA300, 2.5", 7200rpm, 16MB Cache)
Optical Drive (D:) : N/A @ TSSTcorp CDDVDW TS-L633C (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : ASUS (ICH9M) LPC Interface Controller
Audio Device : ASUS (ICH9) HD Audio Controller
Audio Codec : Realtek Semi High Definition Audio
Disk Controller : ASUS (ICH9) Mobile SATA AHCI Controller
USB Controller 1 : ASUS (ICH9) USB Universal Host Controller
USB Controller 2 : ASUS (ICH9) USB Universal Host Controller
USB Controller 3 : ASUS (ICH9) USB Universal Host Controller
USB Controller 4 : ASUS (ICH9) USB2 Enhanced Host Controller
USB Controller 5 : ASUS (ICH9) USB Universal Host Controller
USB Controller 6 : ASUS (ICH9) USB Universal Host Controller
USB Controller 7 : ASUS (ICH9) USB Universal Host Controller
USB Controller 8 : ASUS (ICH9) USB2 Enhanced Host Controller
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Send To Microsoft OneNote 2010 Driver (1200x1200, Colour)
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Wireless Adapter : Atheros AR9285 Wireless Network Adapter (802.11n (HT), 65Mbps)
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 5.3
Old 02-05-2013, 07:15 AM
jmitchell1532 jmitchell1532 is offline
Your Sandra lists one harddrive. Do you have a seperate drive dedicated to your sessions? If so, what type? Avoid green drives. WD Caviar Black are great.
Jon
HP Pavilion P6000, AMD Athlon II X2 240 (2.8GHz), FOXCONN 2AB1 MoBo, 16GB DDR3, NVIDIA GeForce 8400GS, Two WD Caviar Black Internal500 gig, One WD External 300 Gig, Windows 7 Ultimate 64-Bit, SD2, Metal Foundry, Focusrite Saffire 6, PT 9.03 (stable), Gibson Les Paul Studio (Drop D), Fender Tele (nashville tuning), hand built Carvin Bolt (finished!)
Old 02-05-2013, 07:34 AM
Yes, I have an external hard drive as my recording volume. It is a 5400rpm 1T drive. I don't not know what is meant by green or black drives. Could you elaborate?
Old 02-05-2013, 07:38 AM
Hi, Jon. You're not gonna want to hear this, but 5400rpm is usually a show stopper. At least 7200rpm is the way to go.
A "green" drive is any drive marketed as eco-friendly or power-saving. While it sounds good as a marketing term, slowing down speed or shutting off will not help audio performance.
Jon
Old 02-05-2013, 08:51 AM
He's right^^^ Your recording drive MUST be 7200 rpm. Then there's the connection for that drive. Since you are on Windows 7, you can use USB2(not sure on USB3) and eSATA. Windows 7 users cannot use FW drives.
You should also got to Device Manager and disable the wifi when running Pro Tools(at least until things start working well, then try leaving it on and see if it hurts performance).
If you get things to a point where you are happy(fingers crossed), then you might consider doubling up on RAM(4GB is bare minimum), but; A-get exactly the same as what you have because RAM should all be matched, and B-don't spend any money on RAM until the machine proves that it will run Pro Tools with decent performance(no point in investing in a computer that doesn't work). Laptops can be a crapshoot with Pro Tools
Old 02-05-2013, 09:00 AM
sw rec sw rec is offline
Also remember that a SEPARATE recording drive is a MUST here. Recording to a partition on the system drive won't work reliably.
Old 02-05-2013, 11:17 AM
Wowza, you realize Avid's requirements for a hard drive are 5400 rpm? It's pretty frustration to buy one at that speed and then have someone else tell me it's not fast enough.
So you're saying, also, that Pro Tools functions with a FW interface, but not a FW recording drive? I guess I should be able to use the external with USB. Why in the world should this be so? I am having a hard time wrapping my head around all this seemingly arbitrary stuff. Is Pro Tools just a program unlike every other program or something?
Getting back to the OP, though, are any of the suggestions you guys are making likely to solve the "ASIO device properties changed" error? Because that is the single greatest barrier to getting things going right now.
Old 02-05-2013, 11:34 AM
I can't remember AVID ever recommending (insisting on?) anything other than a 7200 rpm drive. Maybe it's a typo. It's a throughput issue.
On XP they recommended FW externals, but the rumor is that Win 7 handles USB better than Firewire, so the protocol did in fact change as of Windows 7.
Old 02-05-2013, 11:46 AM
Just did a hard drive requirement/PT 10 search, and it says:
Avid-approved Audio Hard Disk Drives for Pro Tools 10 Systems
The following disk drives have been tested and approved by Avid for use with Pro Tools HD 10.0 and Pro Tools 10.0 as Audio Record and Playback drives. Drive speed of 7200rpm or higher required.
Almost 3 months now... fenderrocker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-25-2009 05:01 AM
It's been 3 months MEAT Pro Tools TDM Systems (Win) 40 06-09-2009 03:18 PM
So much for two months Pete Bradt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-29-2008 06:16 PM
Six Months Alio 45 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-01-2008 06:41 AM
PTLE 5.0.1 : a month, 2 months, 6 months, a year? Kickin.da.speaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-11-2000 06:51 AM
