Old 04-25-2010, 08:47 PM
elcw elcw is offline
Default MBox2 Mini Problem on Snow Leopard OSX 10.6.3
I have bought a new MacBook Pro Core i5 and using MBox2 Mini as primary sound card driver. Running a Pro Tools 8.0.3 Software. MacOSX Version is 10.6.3 Snow Leopard.
When I use iTunes to play some music, (has been set MBox2 Mini USB as primary sound device) it's works fine but after few second, sound gone...... No Sound and keep on loading process for a long long time. I need to unplug the USB cable and everything back to normal. When I plug back the USB cable of my MBox2 mini, just play some music or sound, happening again........
It's same situation happen when i using pro tools 8.0.3 and I have tested on Windows OS and It's work fine on it.
Can anybody tell me what's happening of my MBox2 Mini? I have been reinstall Pro Tools Software for twice.
Eric Leung
Old 04-25-2010, 09:11 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Re: MBox2 Mini Problem on Snow Leopard OSX 10.6.3
I don't know if this would make a difference in your situation (I'm not a tech, just the forum admin), but I did notice that there are upated components in the latest Pro Tools LE update for Snow Leopard that may apply:
Pro Tools LE 8.0.3cs2 Update for Mac
Installs the following:
Pro Tools LE.app (v8.0.3cs2)
DigidesignMbox2.kext (v8.0.3cs2)
Digidesign CoreAudio.plugin (v8.0.3cs2)
Administrator
Old 04-26-2010, 12:39 AM
Thanks your help, Let me try it tonight! Hope everything will be fine ~
Old 04-26-2010, 05:41 AM
after install the new update 8.0.3cs3, problem still occurs, still crashes the OS.....what can i do?
Old 04-26-2010, 07:26 AM
Gyatso Gyatso is offline
I have the same problem, I have installed the new update 8.0.3 cs but it didn´t work.
-A
Old 04-26-2010, 01:38 PM
DigiTechSupt's Avatar
Keep in mind that the i5 and i7 Macs are not currently qualified for use with Pro Tools.
That being said, try the following:
Try every USB port.
Disconnect any other USB devices.
Disable airport and bluetooth.
Follow all the general Mac troubleshooting steps in the link below.
Best of luck,
Avid Audio Tech Support
Support FAQ
Old 04-26-2010, 04:58 PM
Also note that none of the AVID/Digidesign USB audio interfaces are hot swappable. It can damage your USB port on either the interface or the Mac. So I would immediately stop that. Only disconnect or connect the interface when the Mac is off.
Obsidian Dragon
MacBookPro14,3 - Intel Core i7 3.1 GHz, 16 GB
MacOS 11.6.2 running Protools 2021.12
Old 05-31-2010, 12:02 PM
PeterHoueSørensen PeterHoueSørensen is offline
I tried all 3 USB ports on my MBP. The one most far from the screen worked, so good tip. Would think they were all the same??
Problem detected with audio clock etc...PT10 and Mbox2, Snow Leopard. YouMeOh macOS 5 02-10-2012 01:30 PM
Mbox 2 mini Snow Leopard(10.6.3) problem anti_75 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-21-2010 11:26 PM
Massive Problems... MBox2 Mini Snow Leopard 10.6.2 subterra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-04-2009 11:49 AM
If buying Imac and MBox2 tomorrow: Leopard or Snow Leopard? Jairo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-22-2009 04:13 PM
Mbox2 with Snow Leopard lsmurphy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-06-2009 03:26 AM
