Seriously-read this first!!!!!
Straight from the manufacturer, and people still ignore it....
IMPORTANT! You MUST use a secondary hard drive (not your main OS drive) for recording and playback of audio in Pro Tools. Recording or playback from the OS drive is known to be problematic and the cause of many different error types. If you are using your system drive and encountering errors, the first thing you should do is get a compatible drive. USB drives are not supported and are known to be problematic, so please do not use them with Pro Tools. If you're recording or playing back from a USB drive and are getting errors in Pro Tools, please switch to using a compatible external firewire drive or internal SATA/ATA/IDE drive and disconnect the USB drive. Pro Tools supports recording and playback to a secondary drive that meets the following requirements: 7200 rpm or faster 9ms seek time or faster Firewire drives must have the Oxford 911 (FW400 port), Oxford 912 (FW400 & FW800 ports) or Oxford 924 (FW800 ports) Bridge chip. USB drives are not supported and are known to be problematic. |
Re: Seriously-read this first!!!!!
". . . but my usb stick has plenty of room on it. Its 16 gigs, why can't I record on that. It said on the box its FAST. Isn't Fast fast enough?"
Im joking. . .really. I agree. It seems a lot of folks post about problems using KNOWN problematic things like Old versions of VI's or Plug Ins and these drive issues you mentioned. I research and read whats recommended, not everyone does. It does get tedious pointing out info thats easy to find. |
Hehehe, that's funny, i record everyday on my internal HD without any problem or glitch........ go figure........:) |
I hate to see anyone lose at their hard work when they ignore the recommendations.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Nick
Core i7 920 OC'ed @ 4.0 GHz (200 X 20) 12 GB Patriot Viper Extreme Asus P6T OCZ Agility 64 GB SSD Hitachi 1TB 32 MB HDD WD Caviar Black 500GB Saphhire HD 5850 3 x 20" monitors Eleven Rack w/ ERXP Fender Super Champ XD Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet |
other than the obvious, your putting extra wear and tear on the internal drive since it has to work twice as hard retrieving data. Make sure you back up to something, laugh now, but it's no joke that you would lose all your hard work.
Don't worry i back up with time machine......
90% of the trouble come from plugin that are outdate. |
Not true. that's what a internal drive is made for. retrieving data.
Serious....read this first!!!!! | sw rec | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 10-27-2010 12:16 PM |
the need to read | bo-jingles | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-19-2006 03:40 PM |
Wanna help me? read question 1, Wanna good laugh? read question 2 | 8mmOverdose | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-15-2003 12:29 AM |
Before you Buy Anything Read this!!!!!! | bituminousdisease | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 06-27-2001 12:57 AM |
Read before you buy! | Avid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-21-2000 12:23 AM |
