Old 11-24-2002, 07:12 AM
el matador el matador is offline
Default Nothing Steinberg works with the new DIGI ASIO driver
Nothing Steinberg works, nuendo, cubase sx nor wavelab. but REASON, Logic, and fuityloops work great. reason with 2ms latency.
I am hoping it has to do with how I have my programs installed. Someone please shed light. I have a dual boot setup with WIN ME and WIN XP. To avoid mix ups I install all my XP programs in c/winxp program files rather than c/program files. Could this different location have to do with the asio problems.
SX and Nuendo do see the driver and even let me "switch" to it. but on playback, the bar scrolls but no sound comes out. the meters dont even light. When I go back to the sblive card, it plays back fine.
Digi could you give me some details as to how the asio installation works, where it places certain files maybe. I get the feeling that its just a misplaced file or something. Otherwise I cant explain why all but the steinberg apps work great. I will say it kind of installs funny. when the installation begins, its real fast and doesnt give me "successful" or "finished" message. it just cuts out.
Old 11-24-2002, 11:16 AM
DaveJDoc DaveJDoc is offline
Default Re: Nothing Steinberg works with the new DIGI ASIO driver
I have not heard of anybody getting the DIGI ASIO to work with WaveLab 4.0, but I know Nuendo has been ok. If anybody has had a result with WaveLab please let us know.
DaveJDoc
Old 11-24-2002, 12:44 PM
TheGreenGrocer TheGreenGrocer is offline
Wavelab seems to recognise the DigiASIO driver initially, but cannot accept it for some reason (not that 'reason') sorry,... but, i have successfully gotten cubase 5.1 up and running, and on the 128 buffer setting (44.1khz) 3ms latency on a pIII800eb (22 daveC) ... which aint half bad... seems a little unstable at 48khz, but i didnt close cubase after changing the samplerate... so its probably my on fault...
cheers all
Old 11-24-2002, 06:09 PM
ok but what about cubase sx and nuendo? are you guys having problems?
Old 11-24-2002, 06:35 PM
anthrock anthrock is offline
No problems with SX. Works fine. Just remember to set it up in VST Inputs.
Old 11-25-2002, 01:22 AM
John Stalberg John Stalberg is offline
How about the MIDI ports on DIGI oo1 with the new ASIO? In the read me document DIGI say the new ASIO doesn´t support the MIDI ports. I need the MIDI ports and I am going to run Cubase SX on DIGI 001. Do you have any info about the question about the MIDI ports or anything else. I´m sitting with four PC´s in a school and I will wait until you say it´s working properly.
John
Old 11-25-2002, 02:26 AM
Joz Joz is offline
Cant get it to work on Wavelab 4.0 [img]images/icons/frown.gif[/img]
It doesnt seem to recognize the driver
"I never hit a women with her clothes on!"
Old 11-25-2002, 02:51 AM
Jayman#9 Jayman#9 is offline
<font size="2" face="Verdana, Arial">None at all. Nuendo works great! The only thing I noticed is that when I try to switch from the buffer setting of 128 to anything else, Windows will lock up [img]images/icons/shocked.gif[/img] [img]images/icons/frown.gif[/img] . It runs very solid with a 256 buffer and up though [img]images/icons/smile.gif[/img] . I'm getting more plugins and over all better performance with the DIGI001 rather then my RME ASIO card!
Jayman #9
Old 11-25-2002, 07:31 AM
CJDASH CJDASH is offline
I also am using the ASIO drivers with Nuendo and it works great. I've even tried it in DOLBY PROLOGIC and 5.1 surround and it worked great [img]images/icons/grin.gif[/img] [img]images/icons/grin.gif[/img] [img]images/icons/grin.gif[/img]
Old 11-26-2002, 12:25 AM
And the MIDI ports anyone?
John
Digi ASIO driver 64 bit Greg M Pro Tools HDX & HD Native Systems (Win) 12 10-24-2011 08:53 PM
DIGI ASIO DRIVER PROBLEM WITH FL 8 "Not Enough ASIO output channels available. scottthafoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 04-19-2010 02:45 PM
ASIO Driver and DIGI-001 Dan Lawrence 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-03-2007 10:16 PM
ASIO driver compatible with Steinberg Wavelab 5? OrangeDerek Pro Tools TDM Systems (Win) 5 01-20-2005 02:28 AM
An ASIO Driver that works with Wavelab PedMar Pro Tools TDM Systems (Win) 5 03-30-2004 11:17 AM
