Old 01-19-2025, 01:47 PM
reezekeys reezekeys is offline
Default Re: Timeline messed up on AAF import
Originally Posted by smurfyou View Post
An AAF is an EDL. It is only concerned with the clips position on the timeline. It references the original timecode in the source clip but placement is taken from your sequence not anything inherent to the clip. If that makes sense.
Kinda. How does this apply when you have the same clip in two or three different locations? I must be dense. I took a single clip, copied it and moved the copy few bars away. Same clip, now in two different spots. In DP, both clips show the same "original" timestamp and "user" timestamp. Only when I invoke "Set User Timestamp from Sequence" on the copied clip does its "user" timestamp change to agree with its actual location on my timeline. This is expected behavior in a DAW?
I assume Pro Tools or any other DAW importing an AAF looks at these timestamps to know where to place the clips on the timeline. Am I wrong? It seems to me that once I start sliding clips around, copying, pasting, etc., the timestamps are not going to agree with their actual location on the timeline. How is an AAF transfer supposed to work then?
Old 01-20-2025, 07:04 AM
I've confirmed that, at least in Digital Perfomer, the clips' timestamps do not necessarily correlate to their location on the timeline. I can create a clip and move it to a new location, and both the "original" and "user" timestamp stays the same. So, during an AAF import, the importing app must use some other means to know where to place clips - at least that's my conclusion.
Old 01-20-2025, 08:28 AM
smurfyou smurfyou is offline
That's what I was saying, those clip timestamps have no bearing on where they are located on the timeline. UNLESS you specifically need to spot them to their original timecode.
The timeline/sequence/EDL works like this:
At 01:00:00:00 I will place clip A001 using 5 seconds from that clip:
A001 01:00:00:00 - 01:00:05:00 using 13:02:15:00 - 13:02:20:00
So the clips timecode is used to reference which parts of that clip will be used on the timeline. That what the AAF does.
~Will
Old 01-20-2025, 11:40 AM
OK, the elevator is getting to the top floor...
So theoretically - if I assign user timestamps to all my clips in DP based on their position in my sequence, then get misplaced clips in PT I can just "move them to the user timestamp"? (I assume there's a command to do that). Not a real solution when there's a few hundred clips spread over 20+ tracks in a two-hour project! Maybe if there was a global command or macro to move all clips to their user timestamps, but I think you already mentioned that was not the case. Thanks for hanging in with me.
Old 01-20-2025, 03:00 PM
Yes theoretically true but PT can't do that. Many of us have asked for that feature as a lot of other programs will.
Not sure if I mentioned but I think the last files I got from DP were the embedded and consolidated OMF. If you want me to test something send me a PM.
~Will
  #16
Old 01-21-2025, 03:08 PM
Appreciate the offer, thanks. I'm currently finishing up doing rough mixes in DP - then will tackle getting everything into PT. I didn't think of trying OMF instead of AAF, thanks for that tip.
Interleaved audio 7.1.2 ch order messed up on import Branko Post - Surround - Video 12 02-10-2020 05:38 AM
Import Session Data by Timeline Selection? rossnewbs Pro Tools 12 0 08-23-2017 04:16 PM
Regions not showing on Timeline when Import Session Data migbook Post - Surround - Video 3 03-18-2011 05:44 AM
How to Import Markers and specify Timeline Oriantation. EarHole Post - Surround - Video 4 04-11-2007 09:35 AM
I messed up...Timeline issue in LE PLAbass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-18-2004 07:52 PM
