Old 06-27-2024, 08:40 AM
jehjinho jehjinho is offline
Default can't use waves plugins as favorites
Hi!
Since 2024.6, (or maybe waves v15) i can add favorite or default waves plugins but they disappear every time i reset pro tools.
Anyone?
Old 06-27-2024, 10:00 AM
Default Re: can't use waves plugins as favorites
What the heck is a "reset" in Pro Tools? What *exactly* are you doing?
Old 06-27-2024, 10:28 AM
I'm talking about the plugins i select on a track insert by clicking "control" (i'm on windows, here) on the big plugin list. Then i'll have them more readily available on top of the list.
Also, in Preferences/Mixing there's also a default EQ and default Dynamics, which then appear before the plugin list.
i'm having problems with waves plugins disappearing from the list after i close and reopen pro tools (that's what i meant when i said "reset")
Old 06-28-2024, 12:40 AM
Those settings are all stored in the Pro Tools prefs file. It sounds like that prefs file is not being saved (it's save automatically you should not need to do anything), or maybe your Windows account/file locations/permissions are messed up.
You should also try trashing prefs, in fact you should just try trashing prefs as the first think when troubleshooting a problem. See troubleshooting instructions under "Help us Help You" up the top of each DUC web page.
I no longer use Waves plugins. Does it happen with any others? You can also check that in a setup with no Waves plugins installed by removing the Waves Shell plugin (That's the way Pro Tools interacts with all the Waves plugins) in the Pro Tools plugin folder and see if this all then works with other plugins OK.
Is this you? https://duc.avid.com/showthread.php?t=428944
Old 06-28-2024, 05:52 AM
Trashed PT preferences, unfortunately didn't work.
I tested and any other preference non waves related is still being saved upon exiting PT
Old 06-29-2024, 03:57 AM
modulo2008 modulo2008 is offline
I'm having the same problem.
By the way, PROTOOLS 2024.3.1 saves settings correctly even with WAVES v15.
Other companies' plugins save settings correctly with PROTOOLS 2024.6, but WAVES v15 plugins are reset to "none".
Mac STUDIO M2 Ultra 2023 [24-core/128GB Ram]
macOS Sequoia 15.1.1
Pro Tools Ultimate 2024.10.1 with HDX2 & UAD-2 [20-Core]
Old 06-29-2024, 07:16 AM
BCnSTL's Avatar
BCnSTL BCnSTL is offline
Same issue.
PT 2024.6
Waves 15
MacOS Sonoma
2023 M2 Pro - MacBook Pro 16 -16GB RAM - 1TB SSD.
macOS Sequoia 15.2 (beta).
PT Studio 2024.10 Native.
Life is like an Analogy.
Old 06-29-2024, 10:02 PM
skylar_battles skylar_battles is offline
Same issue as well:
macOS Ventura
Waves V14
Pro Tools 2024.6
Pro Tools Ultimate 2024.10.2
macOS Sequoia 15.2
MacBook Pro 16"
Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine
32 GB unified memory
1TB SSD storage
Old 07-09-2024, 10:44 AM
BCnSTL's Avatar
Anyone had a different result trying to use WAVES as default EQ/Comp?
What OS? What version of WAVES?
Old 07-09-2024, 07:43 PM
It’s interesting that on a different rig other than my own with Sonoma and PT 2024.3 (not sure what Waves version), I’m seeing Q10 show successfully as a default EQ insert and set to not already be inserted on new tracks. So it seems like a 2024.6 bug for sure.
macOS Sequoia 15.2
MacBook Pro 16"
1TB SSD storage
Pro Tools missing V9 plugins from Waves after updating Waves Central williamg AAX Plug-ins 4 12-14-2019 06:54 AM
FS: Waves Kramer Master Tape and other Waves plugins MatthieuH Buy & Sell 0 05-16-2016 09:57 AM
FS - Waves plugins, AVID plugins Rosco1969 Buy & Sell 12 03-11-2014 12:56 PM
FS : Plugins alliance, avid, flux, waves plugins, blastwave sound library Roll Buy & Sell 5 03-11-2013 07:20 AM
AES Favorites lwilliam General Discussion 4 09-25-2000 11:21 PM
