  #141
Old 08-20-2024, 04:33 PM
resonatee resonatee is offline
Default Re: Always having to force quit Pro Tools
Let me share my story. Recently Pro Tools has started to behave sluggish, and was throwing at me errors at low cpu usage of about 30%. Very simple post session, the usual template. So i started to remove plugins, all the virtual instruments (do not need them for this project) etc, etc... Also noticed that PT stopped behaving on quit and was hanging at Closing Audio catalog....had to force quit.
Then I noticed i get clicks in the speakers that are not in the audio files. PT was throwing more errors my way. Cpu too high, remove plugins. At low cpu usage.
Finally i took a longer look at my Audio interface (Metric Halo 2882 3d running over ethernet) Was contemplating changing the ethernet cable, using Usb connection instead of Mhlink, and then, i noticed that one of the Adat cables got disconnected from my AD/DA - Lucid 88192.
Turned out - it was a clocking issue.
Go figure! After connecting the missing adat cable everything went back to smooth sailing.
__________________________________
MBP M1 Max 64GB
Ventura 13.7.1
cMP 2 x 3,46, 128GB Ram
Monterey 12.7.4
Metric Halo 3d 2882 I/O
Lucid 88192 with Blue Sky 5.1 monitoring
10gbE ethernet with True Nas storage
  #142
Old 08-20-2024, 07:10 PM
basslik's Avatar
basslik basslik is offline
Nice you were able to track it down.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.6 & SONOMA 14.6.1 - PT 2024.6 / 003 RACK SIGNATURE MOD / DIGI 003 CONSOLE / DIGIMAX FS / PCM90 2CHANNEL SPDIF
  #143
Old 08-25-2024, 10:56 AM
VideoWorkshop VideoWorkshop is offline
Originally Posted by moogboy100 View Post
Turning off Wifi or FileVault is not a solution nor the solution.
This issue is what it has always seemed to be, an issue with how Pro Tools releases control of the audio hardware/interfaces when quitting the software.
Whether that's due to changing sample rates as mentioned, or using 3rd party interfaces where other software and the OS can also use it as a sound device at the same time as Pro Tools, etc.
It's a software issue in Pro Tools (and/or the OS), and needs to be taken more seriously by Avid.
I think moogboy100 is right. This must have something to do with how Pro Tools releases control of the audio hardware/interfaces when quitting the software.
The freeze on exit is not a problem running under Catalina or Mojave but happens after upgrading MacOS to Monterey.
Pro Tools works fine, opening and closing projects works fine, but Pro Tools always freezes on exit and I have to force quit the app.
I have tried the optimize tips from tope_d and the tips mentioned
I normally work on 48 kHz but tried 44,1 and 96
Deleting preferences
Turning off WiFi and Network
Renamed and created /Users/Shared/Pro Tools
Clean install Pro Tools Ultimate 2023.9 and 2024.6
MacPro 6,1 - OS 12.7.5
  #144
Old 08-25-2024, 11:11 AM
basslik's Avatar
Others mentioned it happens on different OS's.
I"m sure that's the problem not letting go of the hardware.
*AVID*, is it possible the drivers from PT Audio Bridge might be the culprit ?
Why does PT install the Audio Bridge drivers automatically, when the DMG. folder install has a separate install package for the Audio Bridge?
Thank you.
  #145
Old 08-25-2024, 07:42 PM
basslik's Avatar
Thank you.
*UPATE*
Okay I had to import an I/O from Monterey because in Sonoma, it Would not let me change to default for the I/O.
Even when I tried to change to default, the inputs just showed 18, from 9adat to 16adat inputs and the 2channel SPDIF, it would not recognize in the I/O setup. I also tried the change the stereo mix and see if that made a difference. reboot, no change.
So I imported the I/O from a session in Monterey in Sonoma, and all is good. I was going to trash preferences if this didn't work.
*OKAY*, here's what's interesting. In Sonoma I don't have to force quit at all. (HOORAY).
I installed, my iLok and PT with just the bare bones, and nothing else.
I will now install Melodyne (NEXT), then come back, and hopefully no force quit. Then waves, and that's about it.
So my thought's are Silicon related at this point.
I hope Sonoma pans out.
More update. 8-26-24
Installed all effects bundle and so far no force quit. Will now install Melodyne.
  #146
Old 12-12-2024, 11:52 AM
[email protected] ckermo@gmail.com is offline
Sorry, but still having to force quit here, though Mac Intel and Sonoma. Happens after a long session as usual and as described by many of you guys.
  #147
Old 12-12-2024, 03:03 PM
basslik's Avatar
Since I moved from Monterey to Sonoma, the problem mostly went away.
Like you, I too when I have a long session it will hang sometimes.
When working on a long session I find CMD+S and then wait a minute for it to calm down then I quit. It seems to work well that way, but for the most part it went away.
Make sure the system preferences on your computer has full access to the disk.
  #148
Old 01-19-2025, 08:40 AM
Sonopolis Sonopolis is offline
Any news on this?
Just upgraded an old trash can Mac to Monterey and PT 24.12.2 and suddenly having this problem every single time.
  #149
Old 01-19-2025, 11:53 AM
tope d's Avatar
tope d tope d is offline
Originally Posted by Sonopolis View Post
Any news on this?
Can you confirm your Pro Tools version? There's no 24.12.2 version available.
Have you also tried clearing your cache and other optimization steps?
https://avidtech.my.salesforce-sites...ng/Optimize-12
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
  #150
Old 01-19-2025, 01:13 PM
Ptbright Ptbright is online now
9 times out of ten pro tools crashes on closing. On Sonoma/2024.10.1. Sometimes it freezes and have to force quit.
Pro Tools Crashes, Keeps Running in Background After Force Quit gabriel b. Pro Tools 11 2 01-07-2018 01:58 PM
Pro Tools refuses to quit. Have to force quit. SD2 Pro Tools 10 13 01-23-2014 09:21 AM
The following incident with Altiverb will force me Force Quit PT 25ghosts Pro Tools TDM Systems (Mac) 0 03-02-2009 02:30 PM
Pro Tools 7 will NOT force quit... soundfx Pro Tools TDM Systems (Mac) 2 04-20-2006 04:04 PM
Pro Tools must force quit to quit losttimestudios Pro Tools TDM Systems (Mac) 3 03-21-2005 10:32 AM
