Old 11-27-2014, 07:01 PM
soybalm soybalm is offline
Default Re: 11.2.2 change outputs glitch
Originally Posted by ronwasserman View Post
iMac, Yosemite. I've mainly run into this setting buss inputs on VEP aux tracks. Happened a few times yesterday and since updating. Easy fix to close and reopen the session.
Same here with VEP.
Dave Cournoyer-guitarist-project studio
Mac Mini late 2012, i7, Sierra
16GB PT10.3.10HD PT12.5.2
Apogee Mini-Me firewire.
Old 11-28-2014, 04:35 AM
Okay - I don't have VEPro. Maybe that's the issue - VEPro? Do you have the same issues just inside PT without VEPro running?
Jack
QAPLA!
Old 11-28-2014, 10:39 AM
ronwasserman's Avatar
ronwasserman ronwasserman is online now
I've only had it bussing VEP...but that doesn't mean much as I'm scoring and not running a lot of audio tracks or other busses. Pretty much write the bit, mix and bounce in real time in the box to a track and move on to the next cue. (I'm using a Obsidian external compressor so I have to do things in real time.)
Ron Wasserman
https://www.ronw.com
Mac Studio Ultra 2023
Old 11-28-2014, 12:27 PM
Shifted Music's Avatar
Shifted Music Shifted Music is offline
I don't have nor use VEP...
So not just a VEP issue
Jay-J
System
MacPro 12 Core • 24 G Ram • 10.12.6
PT 12.8.1 • Mbox 3 Pro • Plug-ins Verified
4 HD • OS ssd | Audio ssd | Sample Library ssd | Storage
MAXPower eSATA 6G Card • Wiebetech RTX100H-Q
Kensington Trackball Works/Orbit Optical
Bluetooth off/Airport on and off.
Old 11-28-2014, 11:09 PM
holyspicoli holyspicoli is offline
Yep, never had VEP here and am on Mac OS 10.9.5 (Mavericks). I've seen this happen with audio tracks and aux's. The only way to change the track outputs to my main stereo out on certain tracks is to set them to "no output" (thereby erasing any pan settings and automation) and then selecting the output. Seems like a clear bug to me, and like I said been a PT user for many years and 11.2.2 is the first I've seen it.
  #16
Old 12-03-2014, 04:50 PM
Terrible issues with this today........ Simply will not allow VEP plugin Buss to work on some busses. Only in certain sessions.
Restarting and/or rebooting did not resolve this today.
Weird.
Ron Wasserman
  #17
Old 01-19-2015, 07:04 AM
jamieboss1 jamieboss1 is offline
Hi All,
Any update on resolving this issue? It's happening for me on both 11.2.2 and 11.3.
Super annoying.
Thanks,
J
  #18
Old 01-19-2015, 10:38 AM
Sonny Keyes Sonny Keyes is offline
Same problem with Pro Tools 11.3 on Yosemite. Everything behaves normally until I release the output (or input - same problem) selection, and then I see it didn't change. If I do it enough times, eventually it will change, but it definitely slows down workflow substantially. I gave up and started deleting the track and making a new one when I ran into it. Changing I/O in a new track isn't a problem.
Sonny Keyes
Toronto
http://www.sonnykeyes.ca
Rig 1: 2.8GHz Macbook Pro PT 12.7.1 Logic 10.3.2 Scarlett 18i20
Rig 2: 2.66 QuadCore Intel Xeon Logic 10.2.0 Scarlett 18i20 PTHD10.3.10
  #19
Old 01-19-2015, 12:15 PM
Bill Denton Bill Denton is offline
One of those things that can sometimes slip by you...
Are you trying to change to something that might already be in use?
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
  #20
Old 01-19-2015, 01:56 PM
Good thought, but no. If I make a New session then I can assign anything I want to new tracks as I add them. If I start from a template or open an existing session, no such luck, even if nothing is in use yet.
Sonny Keyes
Toronto
How to Change Default Outputs?? teacherman Tips & Tricks 2 07-24-2014 02:04 PM
Tempo Change Glitch Problem & Structure Free Issue mexablcknesekid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-11-2010 10:03 AM
Change Velocity Glitch? lozkane Tips & Tricks 2 02-08-2010 11:57 PM
Change the automaticly set outputs Atarie Pro Tools TDM Systems (Mac) 3 01-05-2005 06:39 AM
Change Wavedrivers Outputs ? Eduardo Apolonia Pro Tools TDM Systems (Win) 0 05-27-2000 11:53 AM
