Just curious if anyone has noticed a performance difference between using a keyboard with MIDI plugged into the USB port of a computer compared to actually using the MIDI port?
I currently use a PCR-50 plugged into the USB port with Reason and find that it misses a lot of key strokes. Anyone else experience this? Thanks! |
Perhaps there is a difference when using usb 1.1 versus usb 2.0?
Hi Sean:
I would say you would most definitely want to have 2.0....and I would assume you do. What're your system details? I use Reason with usb 2.0 and it is absolutely flawless.....I'm pretty sure that it is faster than a MIDI port, buit not positive...don't have a MIDI port actually at all Could the missed keystrokes have a different source? If you're on 1.1 I would say that is probably it....but just about all recent computers have 2.0 as far as I know... Good luck! -Danji
Buenas Noches, Paz, y Jazz! |
Auto input/input only monitoring failing in PTLE 8.0.4 | miketeachesclass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-11-2012 09:48 AM |
Input shows up 10dB+ hotter than actual input | nteeter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-10-2008 04:09 PM |
MBox problem - bad hiss on 1/4" input, but XLR input is ok!(?) | haney411 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-31-2008 11:22 AM |
New to MIDI. Input is quantizing. Input Quantize is disabled | LiamSlack | MIDI | 0 | 03-25-2008 09:59 PM |
I/O LINE INPUT, I/O OPTICAL INPUT DIGI 002 RACK | JOAN ROSALES | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-28-2003 05:08 PM |
