Old 01-19-2025, 07:56 AM
XJENSEN XJENSEN is offline
Default How to solo the MIDI part of an Instrument track?
Maybe I'm missing something obvious here?
On normal MIDI tracks this is easy to do with the Solo button.
But I only see a Mute button for the MIDI channel part on the Instrument track?
Old 01-19-2025, 09:06 AM
K Roche's Avatar
K Roche K Roche is offline
Default Re: How to solo the MIDI part of an Instrument track?
Humm ??
OK first I suggest (For more accurate and efficient and targeted replies ) you list your system in your signature line (like mine below)
That way people will not have to guess or ask what system is,,, which can make a lot of difference on what is actually going on
Second so are you referring to the Midi Controls section and the mute button at the top of the Instrument track ? (light blue arrow)
So it's not clear as to why you would want to solo just that midi input ? As opposed to just using the main solo button (red arrow) ?
System :
Studio - Avid Carbon interface , PT Ultimate 2024.10.2 Mid 2020 (intel) iMac 27" OS Sequoia 15.2
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.10 --Sequoia 15.1
Enjoy the Journey
.... Kev...
Old 01-19-2025, 10:26 AM
tope d's Avatar
tope d tope d is offline
Can you send a screenshot/screen recording of what you're referring to?
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 01-19-2025, 01:07 PM
Originally Posted by K Roche View Post
Humm ??
That's exactly what I was referring to, indeed!
And good point of including a picture from the get go:
I will try to follow your example from now.
This issue came up while troubleshooting a template session that was using (multiple) Instrument tracks to send to external hardware instruments (which is probably a bad idea anyway).
I could not pinpoint where the multiple MIDI streams arriving at the external instrument were coming from in Pro Tools.
In this case it's so useful to be able to just solo one single MIDI output.
With 'normal' MIDI tracks this is super easy to do, but with Instrument tracks there seems no way?
Instrument Tracks Volume Won’t Adjust Unless I Solo Track?? johnbarnesiii Pro Tools 4 11-01-2022 03:52 AM
Can one midi or instrument track, trigger, multiple instrument tracks simultaneously? jamesleonard Pro Tools 2019 5 05-24-2019 08:33 AM
Grouping a midi track with an audio track- only Solo works.. dumbeat Pro Tools 10 2 05-02-2015 08:25 AM
Grouping a Midi track W an Audio/Aux track- only solo works... dumbeat Pro Tools 11 6 04-30-2015 03:09 PM
Midi instrument on Aux vs Instrument Track Superclock Pro Tools 11 12 04-11-2014 01:18 PM
