I have zero latency monitoring setup through a mixer…
When I load a new Audio track I have to pull the fader right down so I’m not monitoring the DAW signal aswell as the signal from mixer…. It’s an extra step to pull the fader Can I load a a new Audio track with Fader at right down? Thanks
Tech:RME Digiface/Ferrofish Pulse 16/ASP880/ Ryzen 5950X /Win 11 Pro 64-bit /Pro Tools 2024.06/ Shure DMK57-52 /Neumann TLM 102/ Oktava MK-012 Mic Pre'sNeve 1073 DPX/ LA2A/1176A/1176F/G Bus Comp Guitars and Instrumentation:Gibson Les Paul Zebrawood/Fender USA Telecaster/Fender Deluxe Strat/ Martin OM-18V/ Martin D15-M/Gibson SG Bass/ 1972 fender Musicmaster Bass/ 1972 Hayman Drums /Vox,Fender Amps/Roland F130R Last edited by easyrider; 01-19-2025 at 07:26 AM. |
You can create a track preset with the settings you want for your new tracks. Then when you create a new track, simply select your preset and the level will initially be at zero.
Sorry about nitpicking, but zero usually refers to unity gain which is neither plus or minus decibels. What you mean by zero would be minus infinity a.k.a. silence
![]() There is also this mystical "mute" button which does not affect to recording.
![]() Quote:
Forgot about track presets! Quote:
Easier to unmute on playback than to pull up the fader Will have a play about and see what suits cheers!
Tech:RME Digiface/Ferrofish Pulse 16/ASP880/ Ryzen 5950X /Win 11 Pro 64-bit /Pro Tools 2024.06/ Shure DMK57-52 /Neumann TLM 102/ Oktava MK-012 Mic Pre'sNeve 1073 DPX/ LA2A/1176A/1176F/G Bus Comp Guitars and Instrumentation:Gibson Les Paul Zebrawood/Fender USA Telecaster/Fender Deluxe Strat/ Martin OM-18V/ Martin D15-M/Gibson SG Bass/ 1972 fender Musicmaster Bass/ 1972 Hayman Drums /Vox,Fender Amps/Roland F130R |
There is also a Preference to Unlink Record and Play Faders (Preferences>Operation>Record>Uncheck Link Record and Play Faders). In any Template, Track Preset or in a Session, set whichever Track(s)' Record Fader to be at the bottom (infinity) and at Zero when in Playback once and the Fader(s) should operate that waygoing forward.
not possible to create a MONO audio track | Kerochan | Pro Tools | 8 | 03-05-2023 02:26 PM |
Can I create an 8 fader custom group on an 8 fader d command? | [email protected] | ICON & C|24 | 2 | 12-21-2020 09:56 AM |
Pro Tools 9 won't play audio after create new track. | shaun_curran | macOS | 0 | 01-26-2011 06:26 PM |
can't create new audio track | Yuen Cheuk Wa | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-18-2002 12:40 PM |
ho do i create a click track for non midi audio | kalle74 | General Discussion | 4 | 05-14-2002 06:34 AM |
