Old 01-18-2025, 09:45 AM
slinky22 slinky22 is offline
Default Can I run Ventura 13.7.2 on pro tools versions (13.6.x)?
I am running ventures 13.7.2, is it okay to run it on pro tools compatibility macOS Ventura (13.6.x) versions?
Old 01-18-2025, 09:53 AM
sw rec sw rec is offline
Default Re: Can I run Ventura 13.7.2 on pro tools versions (13.6.x)?
Not 100% sure what you’re asking here. What version of Pro Tools are you running now?
Typically those MAC “point” updates don’t affect functionality.
Here’s a link to the Pro Tools compatibility chart.
https://avidtech.my.salesforce-sites...795&popup=true
Old 01-18-2025, 10:34 AM
Im running 2023.12(1) pro tools on Ventura 13.7.2, is that okay?
Old 01-18-2025, 11:45 AM
Click on the link I gave you and find it on the chart!
Is it working? It’s okay. :)
Old 01-18-2025, 01:49 PM
yes its working, I just thought you can't download lower versions if your Mac OS version is higher than what it states in the compatibility section.
Old 01-18-2025, 01:56 PM
The download section has no way of “knowing” what your OS is, so you can download anything you have a download link for, AND run it, as long as your Ilok license is good for it. That’s why ya check the compatibility documents and use the version qualified for your OS. Not sure why you would want to go backwards if it’s working, though.
Pro Tools Intro 2023.12.1 / macOS Ventura 13.6.4 Zergei72 Pro Tools | Intro Discussion 4 03-31-2024 11:56 AM
older Pro Tools (18) with Ventura? wmm1 Pro Tools 2018 4 11-08-2023 04:29 PM
Pro Tools Plugins Folder Ventura CKPF macOS 10 06-08-2023 10:25 PM
Pro Tools Compatibility with macOS 13 Ventura newcens Pro Tools 14 02-08-2023 02:18 PM
