Old 08-09-2014, 11:26 AM
howardb howardb is offline
Default Omni Pre-Amp Gain Not Working
Just trying to find out if my problem is actually a broken preamp or a normal Avid "issue".
So my Omnis's i/ps all work (mic/line/1/2), all sound fine but are stuck at their lowest gain. Turning up the gain rotary encoder increases the numbers but doesn't affect the gain. Theres no distortion, and the signal is fine I just can't increase the gain. Have tried resetting a few times, but no luck. Hardware or software? If hardware I assume it's a repair job.
Old 08-09-2014, 05:11 PM
Default Re: Omni Pre-Amp Gain Not Working
Do I remember correctly that you have to push the GAIN knob(like a button) to assign it to the desired input to adjust? Maybe search youtube and see if there are any tutorials on using the OMNI(that might show something you missed)
Old 08-13-2014, 01:20 AM
Thanks for the reply. I should point out it has been working fine both on P1 & P2, and the rotary encoder for the gain is working fine, but suddenly half way through a session, the actual gain in the unit dropped to it's lowest level and can now not be adjusted for both sides and for any ip (i.e. mic / line / inst).
Old 08-13-2014, 01:21 AM
Oh and I have tried resetting multiple times.
Old 08-13-2014, 07:33 AM
Brandonx1 Brandonx1 is offline
Sounds bad. Have you contacted avid? My omni is really sensitive to heat. I have to keep my control room extra cold for my omni to clock correctly.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 08-15-2014, 01:40 PM
Thanks for the reply. Yes I was hoping it was a software thing that people have had, but from the lack of replies it looks like a hardware gain issue which probably means something has blown on the analogue side of the mic amps. Very tedious. And the next stop is to talk to Avid and arrange a repair.
Old 12-15-2020, 07:54 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Hey howardb, I know it's been a LONG time. Any luck with your Omni? Mine has been doing the same thing for about the past 6 months. Stuck in the lowest possible level, the gain number on the display goes up but nothing changes sonically.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 01-17-2025, 08:45 PM
TommyT TommyT is offline
Hey Guys. Is this the same problem ? Long time user, but using the Omni Mic inputs for the very first time.... Seems like the gain is extremely low. Have to turn it up to max to get a recording. This can't be right. tried different mics, different cables, card with 48v and dynamic without... Requires max gain and clip gain on the recording to get any volume... Also plugged in a balanced XLR keyboard into the mic, and at full doesn't clip the input... and line & inst dont work... same keyboard with a TRS connection.. inst works but mic & line do not... So interesting that line seems dead with either XLR & TRS connected.. and mic input is way low ..... on both inputs #1 & #2 as well as the rear XLR Connectors..... Any thoughts ? Am I missing something Obvious Here ?
Old 01-17-2025, 09:21 PM
Lets start with the basics, if you are not clear on how the Mic/Instr/Line connections work find the HD Omni Guide and read up on that. Mic input needs an XLR connector either to front Combi or rear XLR connector. Front panel 1/4" TS is Inst. only and not balanced. Line requires the rear panel 1/4" TRS connector.
For microphones is the input LED showing Mic? Are you going into the front Combi or rear XLR connector with an XLR connector? (and if using the rear XLR you have to unplug any corresponding front XLR). Are you using a known good balanced XLR cable you have tested elsewhere? What exact Mic? Recording what? Is pad enabled on the Omni or on the Mic?
You can always bang out a low level sine wave test signal from Signal Gen on one of the Omni line level outputs and loop back to a Mic input and measure the gain in dB of the mic preamp, this should hopefully be withing a fraction of a dB with the premp setting. Ideally a very quick useful test to see if this is broken or not.
HD Omni line input gain adjustment bissodj Pro Tools HDX & HD Native Systems (Win) 4 02-02-2014 03:00 AM
OMNI Preamp gain stargazer Pro Tools HDX & HD Native Systems (Mac) 4 05-17-2012 01:43 PM
New Omni....Pre Amp Gain Knob Doesn't Work tomhartman Pro Tools HDX & HD Native Systems (Mac) 4 05-16-2012 07:51 PM
OMNI Preamp gain stargazer Pro Tools TDM Systems (Mac) 3 05-14-2012 03:59 PM
OMNI - "control-able mic gain? clusterer Pro Tools TDM Systems (Mac) 5 02-24-2011 03:47 AM
