Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 01-17-2025, 07:37 AM
Zergei72 Zergei72 is offline
Default PreSonus "FIREPOD 10" Windows 10 / 11
Pretty sure this has been covered already ;
But for the sake of sanity, I'm ripping hair just to get my PreSonus audio-interface working with Pro Tools .
No matter what buffer / sample size in the audio-interface's control panel I just can't get Pro Tools accept the audio-device as playback engine . I can't select any of Pro Tools "integral" buffer-sizes and the ones on the "FIREPOD 10" - side won't help either .
I've tried and disabled the PreSonus in the Windows - sound control panel and set the Windows sound system to the integrated Realtek audio or graphic controller's HDMI - output ... won't help matters .
Now, if anyone here has a solution to this, I'd be glad to find a way through .
/ Z .
Old 01-17-2025, 09:24 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: PreSonus "FIREPOD 10" Windows 10 / 11
Do you have a Windows 10/11 driver for that Presonus? That interface is long discontinued.
This information might help.
You also need a TI chipset in your firewire card.
You might be better off with a new interface with current ASIO drivers.
Good luck.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-17-2025, 04:16 PM
I would also dump the old beast as Presonus stopped making drivers for it many years ago. As a last ditch effort, you could try using ASIO4ALL with it, but setting it up might take an afternoon, if it even works.
What good is "Save Copy In..." options "Session Plug-in Settings Folder" and "Root"? ZerglingPhilosophy Getting Started 1 09-02-2022 04:43 PM
Installing from - "Setup.exe Application" or "Avid Pro Tools Windows installer"? ihate100bees Windows 1 05-08-2021 09:35 AM
"Digidesign Midi I/О" in "ProTools 10HD" in "OSX Maverics" electra1006 MIDI 0 06-18-2018 06:46 AM
Presonus faderport punch in footwitch "laggy", PT11. Any fix? musicmixer04 Pro Tools 11 4 01-10-2015 07:21 AM
002 rack "clicks" and Windows beeps when "Setting Up Midi" or sw0mgt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-03-2012 04:42 PM
