Old 07-11-2012, 12:32 PM
postmike postmike is offline
Default Video Satellite gone squirly
MacPro 8Core 2.26, 12G RAM, OS 10.6.6, PT10.2 HD2 Accel w/3x192IO and Sync
Mac Mini 2.53Duo, 4G RAM, OS 10.6.6, PT9.0.2 w/Video Satellite Option
Mini is connected via CAT5 to MacPro
Out of nowhere this morning, this otherwise fully functional setup has been giving me a "Failed to Connect" error every time I try to link the 2 systems via peripherals>satellites menu.
I've rebooted both machines, trashed prefs and rebooted, double checked the TCP/UDC ports all match, Satellite Mode Enabled on the Satellite end, swapped out the CAT5 cable.
The Mini shows up as an option in the "System 2" drop down menu on the MacPro rig, so I know they see each other.
Prior to the "Failed to Connect" message I was having 2 problems (when it was connected):
1) Playback off the Mini is consistently off by exactly 3s 14fr (23.98fps Timecode). Video file in my MacPro session is at 1 hour exactly. Video file in the Mini session is at 1 hour exactly. Lock the machines, hit Play on the MacPro...both videos play, but the Mini is running 3:14 later than the Pro.
2) Lots of "Mac Mini local was disconnected by a network error. Reconnect?" errors during playback. Have to reconnect every few minutes. Sometimes it works sometimes not.
This system was perfectly stable a week ago. Not sure what is going on.
Any help much appreciated.
Old 07-11-2012, 12:48 PM
Dabbler Dabbler is offline
Default Re: Video Satellite gone squirly
Double check the Video frame rates match on both machines' Session setup.
I recently trashed prefs on the Satellite machine and the frame rate reset to 24 from 23.98 and it resulted in similar phenomena.
Good luck
"Video Satellite Option 1.0 - Authorization Error" - without Video Satellite Matts macOS 7 06-29-2011 08:32 AM
Confused with Video Satellite LE /Satellite Link kd_special Post - Surround - Video 0 12-02-2010 08:42 AM
Video Satellite and Audio Satellite - Sorry, I´m confused NOW! Mubeau Post - Surround - Video 6 05-03-2010 02:13 PM
Video Satellite LE - Enable Satellite Mode is greyed out? Erik Olsson Post - Surround - Video 6 01-11-2010 09:16 AM
Video Satellite LE and Satellite Link !!!!!! dr sound Post - Surround - Video 10 10-09-2008 07:11 PM
