Mp3's importing LONGER than source
I was asked to export a piece of music I had cut as an mp3. Composer writes me back to say the cue is drifting out of synch. Session is 48k/24B.
I did a bounce to disk, MP3 Interleaved 16B 48k, slowest encoding speed, 192kbit/s. Reimported the new MP3 file into the same session and lined up against the original material the MP3 conversion is longer by 15 timecode frames on a 2min22sec clip. It's subtle but this music is cut very tight to picture and so you notice it after a bit. Not a pullup/down issue. Seems to be happening on both Pro-Tools version 9(.0.6) and version 10. I did a quick search on the DUC and couldn't find anything relevant so I'm posting. Thoughts? |
MP3's importing LONGER than source
I did a bounce to disk, MP3 Interleaved 16B 48k, slowest encoding speed, 192kbit/s. Reimported the new MP3 file into the same session and lined up against the original material the MP3 conversion is longer by 15 timecode frames on a 2min22sec clip. Not a pullup/down issue. Seems to be happening on both Pro-Tools version 9(.0.6) and version 10. I did a quick search on the DUC and couldn't find anything relevant so I'm posting. Thoughts? |
Re: MP3's importing LONGER than source
Don't use MP3's if you care about sync. When you convert to MP3, it alters the timing so it can do the masking and compression. Stick with PCM files.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Re: Mp3's importing LONGER than source
The obvious answer is .... don't send out MP3s as your final mix. I would not trust it.
Any reason why you have to send Mp3s? Try opening the mp3 in QT player, export as a wav, import that into PT. Any difference? kasper |
A) Obviously it's not a final mix, just a demo for the director and composer. (feature Post-Production)
B) I sent MP3 because they asked for MP3, I hate the format personally. Clearly I don't use it much otherwise I'd have run into this before. C) I'll try the QT thing, but it still doesn't solve the problem of shipping MP3s in proper synch when requested. Is this a known bug? Or is it just life with MP3 conversions? |
This shouldn't be happening. 320k MP3 is broadcast standard here in Toronto for radio commercials. Though we're only talking 30 seconds. I'll try a longer export at work tomorrow and see if I get similar results.
Pro Tools Ultimate 2021.10 - macOS Big Sur 11.6 10 Core iMac Pro 64GB RAM - Radeon Pro Vega 56 8176 MB UA Apollo x8 |
If you are curious to know more about MP3's: http://wiki.hydrogenaudio.org/index.php?title=MP3 As I said, as Kasper said, do not send MP3's if you care about timing. Just tell the director that the timing issue is due to MP3 encoding and decoding and you need to send a wave or aiff. I mean, it's a 2 1/2 minute clip, the file can't be that big. Sendspace, FTP, Yousendit......
↑↑↑ we have a winner ↑↑↑
best, rich
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Something weird here. I bet its a sample rate thing. I've never had an mp3 drift unless that sample rate was wrong. Sounds like the director is working at 44.1 and you are working at 48k. I've run across that before, and the edit never knows how to check or change it. |
WTF Blue Screen from importing MP3's to session?! | jmac146 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-07-2011 05:34 PM |
Importing MP3's | SillySillyStacy | Pro Tools M-Powered (Win) | 5 | 01-30-2006 04:42 PM |
bounced mp3 file longer than source file | chobbs | Pro Tools TDM Systems (Mac) | 4 | 01-24-2006 03:00 PM |
Importing MP3's into P Tools | mghill1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-25-2003 09:43 PM |
MIDI files no longer editable after importing to another session??? | el biciclista | Pro Tools TDM Systems (Mac) | 2 | 06-12-2002 12:56 AM |
