#181
Re: Re-learning to mix ITB?
Derek, thanks a lot!
So I think from what you say, that calibration is very important.. I can think of one situation to compare.. If I am doing a live show on an analog console with only VU meters, I am applying gain according to what I hear and almost not looking at the meters.. I will bring up the kick or vocals until it "feels" right at the hall and then build my mix from there. As long as the system is calibrated and has enough headroom, everything will just fall into place.. With all faders around 0dB! Never thought about interpreting this working habit to studio recording (Maybe because of that "record as hot as possible and then use the faders" thing)... And if talking about calibration, Should I just do it with references, getting used to a certain SPL level, or only the scientific way, with the SPL meter showing 83dB with pink noise at -18? Anything more creative maybe? And one more thing you clarified for me is that the 0Vu=-18dBFS IS based on how a VU meter actually behave and I should read the average levels and not the peaks, that means that a snare hit will essentially read higher than a bass guitar, distorted electrics or synth parts... But the actual point is to LISTEN and FEEL, and not to worry about levels, they can only go wrong in an uncalibrated environment. Hope I got you right. The part about having the faders around 0 so movements are more precise was well understood before, didn't question this. Thanks for your help, I am sure going to learn a lot from your posts that you referred me to, and I will download and listen tomorrow when I am back home |
#182
Or, if you have a calibrated setup, and you still "record as hot as possible" you might be pushing the level at the preamp too hot by maybe 20 or 30dB, and then you end up pulling the fader down by 20 or 30dB, when you could have just pulled the preamp gain down and left the fader at 0. so yeah, you got it right.
Derek Jones Sound Engineer / Producer / Composer Derek Jones Linkedin Megatrax Recording Studios Megatrax Studios Yelp Page A-list Music Artist Page |
#183
Agree 100%, but I have a question... If I import in a PT session a reference mix taked from a commercial Rap Hip hop RnB Cd , how much I have to trim down the volume ? there isn't a standard ? -6 ? -10 ? And If I have to import the file on ssl consol? I Think that if I don't trim down it on ssl , the channel would be permanently red peaking distorting. Right? |
#184
Having said that I agree with everything he said.
"It aint about the stuff you got..If it sounds right you're finished..Burn it!" For all complaints click here DAW-Digi003 PC-Sweetwater CS dual 3.0/Asus 975X Chipset/CPU dual 3.0GHz/800MHz FSB/RAM 4GB/Radeonx300se/4 internal glyph sata drives/ 3 external glyph backup drives/Acronis True Image OUTBOARD-UA LA-610, ADL-600, Digimax lt, Eureka x 2, Central Station, Hearback x 8, JBL LSR, Monster Power Software-PTLE 8.0, Sound Forge, CD Architect Plugins- Too many and too much money spent |
#185
Great, all this forum needs, another lurker with a massive great bunch of TDM chips on his shoulder.
#186
Hey mid, what are you talking about?
#187
This is the *TDM* forum on *MAC*.
Not the *LE* forum on a *PC*. |
#188
so... What's wrong ?? For posting here wee need your permission? |
#189
Look at scar97's rubbishy semi-pro gearlist. I wasn't talking about you. |
#190
You can do better than that, commenting on something you know nothing about. I have 4 TDM systems and 5 Macs. I also have PC and LE. If you ever need help PLEASE contact me. I really think you should really show who you are and get mad at me and use some of your huge mental database to do a better job of trying to embarrass someone who only made one joke. You don't know me or anything about me and let's just leave it at that. I know you will have the last word as i won't respond so do a good job. I know you can! I hope you grow up.
learning the 003 factory | gclef101 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-07-2009 05:29 PM |
Learning BFD???? | finalcut | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-20-2007 09:49 PM |
Learning how to use EQ | Meat Truck | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 11-16-2002 03:35 AM |
HELP...I'm still learning | CodeBlue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-24-2002 04:02 AM |
Learning how to EQ | sidereal | Pro Tools TDM Systems (Mac) | 4 | 08-19-2001 07:11 AM |
